Results 1 to 2 of 2
Thread: Problem building a new computer... can you help diagnose?
    Apr 2005
    Toronto, Ontario
    I'm trying to put together a computer (it's not for my car, that PC is already running great ).
    I build it, plug it in, motherboard LED turns on, I hit power, and everything turns on, but I get no video. No beeps either.
    I take everything out except for the CPU and heatsink/fan, and hit the power button.
    Yes... 1 long, 2 short beeps! I think that means that the CPU isn't dead And I believe that that code indicates a video problem.
    I tried the following combinations: RAM in/video card out, RAM in/video card in, and RAM out/video card in.
    Results:
    RAM out, video card out: As stated above, 1 long, 2 short beeps.
    RAM out, video card in: 1 long, 2 short beeps
    RAM in, video card out: Nothing. No beeps.
    RAM in, video card in: Nothing. No beeps.
    This seems like bad RAM, but can it possibly be anything else? Why am I getting a video error?
    This is all new hardware, so I don't have parts laying around that I can swap in and out to test.
    Computer specs:
    Intel Pentium 4 630 (3.0 GHz, 2 MB L2, 800 MHz FSB, LGA775, H/T)
    Asus P5GD2-X Socket 775, Intel 915P
    KingMax 1 GB PC4300 DDR2 533MHz 240 Pin Unbuffered
    Asus Extreme AX300SE-X/TD ATI Radeon X300 SE
    Antec Lifestyle Overture II Case with 450W PSU
    TIA for any input!
    '03 Intensa Blue Pearl Lexus IS300
    Specs: Xenarc 700TS, Opus 150W PSU, CarCPU Case, 2.0 GHz Celeron D, DFI PS-35-BL, SB Audigy2 NX, Centrafuse 1.4
    Progress: Car PC up and running!
    To Do: Navigation, WiFi, AM/FM Radio, DVD
    Elsewhere
    You need to find what that beep code means. Your diagnosis of bad RAM is certainly a possibility, but that beep code is going to give you the definitive answer.
    Check this link, which makes a good starting point:
    http://www.sysopt.com/forum/showthre...hreadid=146656
    According to that, it's a video card problem. That resource isn't the end-all/be-all, mind you.
    How about the Wiki?
  1. Replies: 15
    Last Post: 10-08-2009, 11:02 PM
  2. Replies: 5
    Last Post: 11-08-2005, 10:04 PM
  3. Computer becomes unresponsive, inverter problem?
    By tsb4k in forum Power Supplies
    Last Post: 10-23-2005, 03:22 PM
  4. Replies: 6
    Last Post: 04-22-2005, 02:05 PM
  5. help diagnose dvd drive problem
    By tsai in forum General Hardware Discussion
    Last Post: 03-06-2005, 10:34 PM
