The opus 150 should be able to power that setup. If it doesn't, then you'll have to underclock the processor.
Hello!
Before I hit that buy button on newegg, I want check in with you guys and make sure that my Opus 150W will be able to support this combo (Click Here) with no power problems..
That is a AMD 2800 Mobile so I'm thinking the low voltage will help a bit but not sure.. also the mobo itself..
Emo
What peripherals are you planning on running off of this OPUS 150? You need to take into consideration the motherboard, CPU, PCI cards, cooling fans, optical drives, video cards etc. Figure out which of these you will be using, how much power each of them need (check their specs), and that will answer your question for you.Originally Posted by Emo
Don't hold your farts in! They travel up your spine, into your brain, and that's where you get crappy ideas from!!!
