Do you have a Multimeter or Voltmeter?
Check the voltage across your battery during a full load at idle. Does it drop below 12v? If so, check your alternator cable connections and clean/tighten your battery terminals/connections. Does it still do this?
Also, check the voltage at your PSU. If it is lower than at your battery, you need to address your wiring/connection.
Always better to diagnose than to spend $$ on on parts that you may not need. It may also be your alternator.
You can find multimeters for super cheap at Home Depot or you can invest in a good one from Fluke.
LinkBack URL
About LinkBacks
