Results 1 to 6 of 6
Thread: How much screen possible
    Variable Bitrate seninha's Avatar
    Dec 2005
    Holland
    How many screens possible
    For my carPC project I'm gonna use a EPIA VIA V800 mobo.
    This board has 1-VGA and 1-TV-out.
    The plan is to usa a 7" TFT touvhscreen in front and two 7" TFT in my headrest (for the kids)
    Will this board handel this or do I need to use a PCI VGA videocard
    Low Bitrate grimor2000's Avatar
    Dec 2005
    Chicago-ish
    as long as you run them all at the same resolution you should be fine
    Causa latet vis est notissima
    VIA SP13000
    1GB DDR400
    Slimline Slot-load DVD-RW
    60GB 2.5 Inch SATA 5400RPM
    Dual Active PCI riser
    PCI TV/FM card
    Logisys FP800
    Thermaltake VFD Media Lab
    M1-ATX
    Dec 2005
    Holland
    Oke That means I don't need to use something like a Real Magic PCI card
    Low Bitrate scfountain's Avatar
    Sep 2005
    Southeast Texas
    Quote Originally Posted by seninha
    How are you planning on hooking all of these monitors up to the board?
    I recommend using a VGA Splitter. Hook the one VGA cable from the motherboard to the splitter, then connect the 3 monitors to it. And hook the USB cable from your one touchscreen monitor to the motherboard. It should work. For info on the splitter, check out http://www.xenarc.com/product/index-peripherals.html
    Don't hold your farts in! They travel up your spine, into your brain, and that's where you get crappy ideas from!!!
    Elsewhere
    He's talking about using the VGA and the TV-out to control two different monitors, scfountain....
    In that scenario, a VGA splitter isn't necessary.
    How about the Wiki?
    Sep 2005
    Southeast Texas
    Quote Originally Posted by DarquePervert
    Your right, in that scenario a VGA splitter isn't necessary. But, if you care to read the member's question again you might understand that there is no implication that he is solely referring to using the TV-Out. He is simply advising that he has 1 VGA, and 1 TV-Out. The member is also inquiring about using a separate VGA card to make this work. At this point, any recommendation is satisfactory.
  1. Replies: 28
    Last Post: 01-30-2011, 02:33 PM
  2. Replies: 37
    Last Post: 03-19-2010, 02:08 PM
  3. Replies: 5
    Last Post: 04-30-2004, 12:25 PM
  4. Gamecube screen
    By junior in forum LCD/Display
    Last Post: 11-24-2003, 07:38 AM
  5. BMW pre-installed system - TFT ?
    By tsingsu in forum LCD/Display
    Last Post: 08-05-2002, 03:16 AM
