Well I put in a generic no name FM modulator in my car about 3 months ago. I have been using it for a portable CD player and it sounds great (compared to a tape deck adapter)! It took me about 15-20 minutes to get it in my 95 Dodge Intrepid. It is not hard at all to install.
You should have three wires (12v - Ground -Acc) and an antenna input and output. You can hook the 12v to the car battery or if you are lazy you could hook it up to your cig lighter. I hooked the ground to the ground in the back of the stereo receiver.
Now you will need a switch to turn it on and off, as you can't really leave it on all the time cause it messes with the rest of the radio stations. Just attach the acc wire to a switch and a 12v current. Now unplug the antenna wire from the stereo and plug it into the modulator. then plug the modulator into the stereo.
As to where to put it. That is up to you. I just left it sitting behind the radio. There was plenty of room there. I just put a switch by my gear shift and ran an RCA cord to the floor of the passenger side for the input. I don't think the side of reciver matters (I an guessing you mean DIN size), mine is a double DIN.
Hope this helps,
Maveric
LinkBack URL
About LinkBacks
