Results 1 to 9 of 9
Thread: Through Roof Mount XM Antenna
    Variable Bitrate cherrybomb's Avatar
    Apr 2005
    Southern Califorina
    I can't seem to find one ANYWHERE! Everything seems to be the mag mount style.
    I'm evidently one of the few weirdo's on the planet that actually WANT to cut a hole in my roof and mount an antenna. I just think it'll be more secure.
    I've thought of using one of the antennas from the new GM trucks, but I can't seem to find those used anyway, maybe I'll check out a dealership, though I imagine that'll be super expensive.
    Is a mag mount really that secure? Can I go through a car wash with it on? I don't intend to ever remove the antenna, so a permanent, through roof mount is very attractive to me.
    I've searched quite a bit, so if I've missed something, I appologize!
    '99 Ford Explorer Eddie Bauer
    CarPC Progress ~= 97%. Everything is installed, and operational. Still need to tweak and tune, and do some "finish" fabrication.
    CarPC Project Web Site
    SpaceNavigatorDriver SourceForge Project
    Check out my blog.
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    Honestly, i've had 2 cars both with mag mount XM and mag mount GPS antennas, I go through both styles of car washes (brush and brushless) without any issues whatsoever.
    but I can't say i've ever seen a through hole XM antenna
    肚子笑痛了
    S60 Install
    Apr 2005
    Southern Califorina
    Well, that's somewhat encouraging.
    I'm still keen on the OEM look though. Maybe I'll just mag mount it for a while, and see how it goes.
    Check out my blog.
    Maximum Bitrate sfay93's Avatar
    Feb 2004
    Omaha, NE
    My mag mount has been through countless carwashes as well without a problem at all. It has also been rained and snowed on. Worked through the snow without a problem of course.
    ATVMS.com
    Spring Hill, Florida
    My Impala came with an OnStar antenna so when I installed my XM antenna I unscrewed the Onstar antenna and ran the wire through the stock opening in the roof. The XM antenna sits behind the OnStar antenna and looks factory.
    2005 Black Chevy Impala
    Apr 2005
    Southern Califorina
    Quote Originally Posted by Shelbrain
    That's pretty cool!
    This is the sort of thing I'm after. I'm thinking maybe I can just find an antenna "cover" or something like this. That way all the wires are hidden.
    I just hate the idea of a wire running to some trim or something. Seems kinda amateur.
    Check out my blog.
    Newbie jpneflim's Avatar
    Jun 2005
    Las Vegas
    What about mounting the antenna in the car. I'm not familiar with XM but I have my SIRIUS antenna mounted on my dash tucked into the corner and I don't have a signal problem.
    Mar 2008
    I am also looking for thru-roof antennas for XM radio.
    It does not have to be of specific shape. But, I want a permanent mount with antenna wire thru the roof of my car by drilling a hole thru the roof.
    Any URL for such antennas would be highly appreciated!
    Oct 2010
    Through the Roof Antenna
    I have used the micro antennas as a through the roof antenna. The XMMicro antenna works best since it will allows the wire to be turned down through a hole just large enough to push the connector through. Once positioned use a silicon sealant around and in the hole then pull the wire taught pressing down on the antenna. The magnet base with hold it in place and you end up with a clean no wire installation. It works perfect. I always place the antenna in the center of the roof just in front of the sun roof and behind the windshield. This allows the hole to be drilled through the roof from inside the sun roof switch cover and the wire is hidden under the edge of the windshield molding over to the door pillar and down under the dash to the radio. This same thing would work if you want the antenna in the rear of the roof.
    It is a nice clean installation and there are no wires visible Works for me.
    Good LucK
  1. XM Satellite Radio to Unveil XM Advanced Services at 2006 Consumer
    By Will Albers in forum General MP3Car Discussion
    Last Post: 03-27-2006, 09:49 PM
  2. XM Antenna for any XM Ready device. $25 Brand New
    By viper24 in forum Classified Archive
    Last Post: 11-07-2005, 10:27 PM
  3. LCD Roof Mount for Taxi - Options?
    By Traumahawk in forum LCD/Display
    Last Post: 07-03-2005, 04:16 AM
  4. looking for a roof mount for a linksys type antenna..
    By bmo in forum Wireless Communications
    Last Post: 04-10-2005, 06:18 PM
  5. Through glass mount wifi antenna
    By n8scstm in forum General Hardware Discussion
    Last Post: 01-31-2005, 09:11 PM
