Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: Do I have to re-install windows if I change the Power supply?
    Constant Bitrate chewEboy's Avatar
    Oct 2005
    ok so after LOTS of hard work ive finally got everything in and working .... well sort of
    thing is.... PC boots up but wont load windows... it keep locking up before it loads
    wont boot up in safe mode either.... you get that list of stuff come up then it stops and one and just sits there
    is it because I set the PC up using a different PC?
    because thats what I did, I used a ATX case and conected everything to a house PSU.... installed windows and what have you.... then just swaped the power to the car 12v PSU
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    No PSU does have nothing to do with the OS (maybe the MB doesn't have the power that it needs to boot up but that is a whole diferent thing)
    Thanatos.
    RexBruMet Skin for FrodoPlayer
    Nissan Aux-in MOD
    Quote Originally Posted by bgoodman
    We're an international forum, post in whatever langauge you like.
    Super Moderator xBrady's Avatar
    USA
    Same thing happened to me when I first installed my carputer. Found out it was because my Opus wasn't set up right, and in the house I was using a different power supply.
    To answer your question: No you don't have to reinstall windows when you change the power supply. You most likely aren't getting enough power for it to boot.
    Installed.
    -GPSSecure- - GPS Tracking
    Nov 2004
    I said that but cus my english is crap nobody understand me
    Oh and BTW I will need gramma correction when doing the review for FP...
    Thanatos.
    Nissan Aux-in MOD
    USA
    Quote Originally Posted by thanatos106
    Thanatos.
    I understood what you said I was just restating it
    Ok, when you post the thread just send me a PM and I'll fix it up.
    Installed.
    Oct 2005
    Quote Originally Posted by xBrady
    thats for restating it as I didnt get what he said
    now.... not enough power??
    well how come its turning on then?
    what do I need to do then?
    USA
    Quote Originally Posted by chewEboy
    Firstly, post your pc specs. What I did was underclock my cpu a tiny bit.
    Installed.
    Maximum Bitrate seanz0rz's Avatar
    Jun 2005
    Cal Poly Pomona or Redlands, CA
    what are the specs of your system? it might be that its just too large for that psu to handle.
    also, reseat EVERYTHING. mem sticks, video card, pci cards, and even your processor if you can. things get jarred loose some times.
    1998 Toyota 4Runner SR5 V6 4x4 in Evergreen Pearl Metallic, Lifted, Locked, and Armored. CarPc in custom console with molded touchscreen.
    Pictures
    Photobucket is being updated, if a picture i posted no longer works, please PM me.
    Oct 2005
    Quote Originally Posted by seanz0rz
    get more power?
    well its a M1-ATX power supply.... max output of 90w
    I thought thats all I would need...
    > its hooked to a standard ATX mobo (I was told that would only use about 40-50w)
    > also got it hooked to a normal HDD and CD rom
    > The only things conected to it are a keyboard and the USB cable that goes to the PC
    Pc is a 128mb ram (got a 512mb stick that ive not put in yet as I wanna get it going first)
    its a AMD athlon 1700
    errr MSI ultra 745 mobo
    guess ill just have to disconect the CD rom and the screen USB thing.... see if that makes a difference
    USA
    What cpu do you have? Or did I miss that somewhere.
    Installed.
  1. My low cost, easy to build power supply...
    By SkinnyBoy in forum Power Supplies
    Last Post: 09-27-2006, 06:10 PM
  2. Do I need another power supply
    By gdawg in forum Newbie
    Last Post: 08-27-2005, 07:25 AM
  3. Choosing a power supply now.
    By Osiris in forum Power Supplies
    Last Post: 01-31-2005, 05:51 PM
  4. Replies: 5
    Last Post: 06-16-2004, 12:41 PM
  5. AT power supply questions
    By JustAGuy in forum General Hardware Discussion
    Last Post: 07-26-2000, 04:35 AM
