Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: Help Trying To Fit Dsatx Into Ampie Case
  1. #11
    Maximum Bitrate Caelric's Avatar
    Sep 2005
    Bellevue, NE
    Quote Originally Posted by MobiTekLink
    Red, 12v Live from battery, preferably... ... Good gauge wire should be used (less than 8 gauge pref)
    White, 12v ACC, ignition or radio..Regular 12 gauge wire can be used.
    8 gauge for the power? Wow, that seems a bit excessive.... I'm using 10 gauge for my power and ground; the amps on my car, including a JL 500/1, get 4 gauge, though. I have 0/1 gauge running from my battery to a distro block in the trunk. I figure 10 gauge from the distro block to my DS12VD is plenty, considering it is meant to be a low power solution.
    Anyways, sorry for the minor threadjack...
    Dave
    2005 Infiniti G35 6MT Coupe Black/Black
    Core Duo CarPC
    CarDomain page
  2. #12
    Oct 2005
    Not trying to be a dick, but if you needed help figuring out that red is power, black is ground, and white is ignition, you may not want to continue doing this stuff on your own.....
    If you are wiring the unit on top, you won't even be using the wires that came with the ampie....the ENTIRE point of those wires is to run the power inside the case.......
    Just hook up the ground, ign, and power to the PSU directly from the source in your car.... then run the 24 pin cable into the case and into the motherboard, DONE.
  1. EPIA M10000 m/b & Travla C134 case fit problems
    By Bxscig in forum General Hardware Discussion
    Last Post: 04-01-2006, 10:28 PM
  2. Opus CarPC Case .. anyone have it?
    By replicant in forum General Hardware Discussion
    Last Post: 09-29-2005, 06:09 PM
  3. Will an OPUS 150W fit in a standard ATX Case?
    By hd54321 in forum Power Supplies
    Last Post: 03-30-2005, 04:38 PM
  4. Epia M10000 in Cubid 3688 case... hard disk does not fit
    By Urinemachine in forum General Hardware Discussion
    Last Post: 04-29-2004, 03:52 PM
  5. To case or not to case?
    By dummptyhummpty in forum General Hardware Discussion
    Last Post: 04-08-2004, 06:19 PM
