If it does this when just listening to a CD on the headunit, you can pretty much rule the PC out as the problem.
May want to check a forum somewhere or do some research on that issue with that head unit.
Are you running it through a 4 channel amp or just directly from head unit to speakers? Does it only do this at certain volume levels?
LinkBack URL
About LinkBacks
