Results 1 to 10 of 11
Thread: AMD Geode NX 1750
    Low Bitrate romanman69's Avatar
    Jan 2006
    AMD Geode NX 1750
    Hey, i saw a great deal for the AMD Geode NX 1750, which runs at 14 watts and is 1.4GHz with a biostar mobo for 85
    http://www.directron.com/m7vig4comb29.html.
    I havent heard much about the Geode CPU's. Does any one have any experiance with the Geode, since few-non is posted about them. They seem perfect for a car PC: little heat (can operate fanless) and little power.
    I guess my biggest question is if the 1.4GHz is enough to run a car PC with DVD, XP, GPS, ....
    Newbie Gortok's Avatar
    Sep 2005
    Canton, GA
    Newegg has a Jetway board now...or did...
    I guess I bought their last one...
    <SOLD>
    ATi RS485 AMD S939 Venice 2GHz (Yes, I had a A64 in my car!)
    CURRENT
    Jetway J7F3E-PB Geode NX1750, 512M, 120G 2.5" SATA HDD, Sony slim combo drive, Lilliput 7"touchscreen, 60G external WD, GPS, WiFi, mini-keyboard
    Maximum Bitrate fixerofallthing's Avatar
    May 2005
    Lawrenceville GA
    Quote Originally Posted by Gortok View Post
    I saw you had your other setups for sale, so what board did you get and what case are you putting it in?
    The Car 2005 Scion xB
    The Truck 2004 GMC Canyon
    Sep 2005
    Canton, GA
    Jetway's J7F3E-PB from Newegg. I'm putting it in a
    http://www.newegg.com/Product/Produc...82E16811165041
    NEEEET little case...
    It was "SOLD OUT" , then they had it, I ordered, and NOW, the price has jumped up $10...WHEW....just in time
    NOW...to find a decent 2.5" SATA drive...
    <SOLD>
    CURRENT
    Constant Bitrate kwchan's Avatar
    Dec 2006
    Singapore - Smallest country in Southeast Asia
    is the CPU included for newegg's J7F3-PB?
    Sep 2005
    Canton, GA
    YEP...
    The heatsink was hanging on one clip, so make sure that it's installed correctly before starting it up.
    I'd like to take this opportunity to also say that the core of the cpu was covered with about ten times as much thermal interface material than what was needed. It covered almost the entire cpu. What a mess!
    I cleaned it all up and put on some good stuff...
    I'll probably end up putting on another heatsink anyway. This fan is a little louder than I like. I think it's a 50mm fan and it spins at ~5K rpm...it whines a little like a harddrive...I'll know more once I get it in a case...
    <SOLD>
    CURRENT
    Constant Bitrate BrianMay's Avatar
    Oct 2004
    Lisbon, Portugal
    how does it compare to the boards with the c7 1.5ghz cpu? and the graphics, is there a better performance than the other boards (jetway j2f2 boards)
    Virando costas ao mundo
    Orgulhosamente sós
    Glória antiga, volta a nós!
    FLAC evandude's Avatar
    Mar 2005
    Maine
    One thing is, unless it says otherwise in the item description or something, it's probably safe to assume that the mobo won't support standby. I've bought a couple of boards as "combos" with uncommon processors (such as the geode) and they didn't support standby. Micro-ATX boards you might want to avoid
    Haven't had that particular board, though, but it's just something to look out for, if you care about standby.
    The PC CHIPS motherboard combo that I bought that came with a geode processor turned out to be a complete waste anyway. Just because the processor is low-power doesn't mean the mobo will be. Comparing between that board and a similar board with an athlon XP-M, the power consumption wasn't even that much lower, and the overall consumption was still several times higher than that of the CPU itself - I don't remember the specifics, but I think it was around 55-60W. It's not that surprising, because real low-power boards like the EPIA series are designed from the ground up to be efficient, whereas these combo boards are nothing but regular mobos with some minor tweaks so they work with the geode (or other) processors which didn't exist when they were originally designed - and these mobos weren't exactly high-end in the first place.
    Anyway, just some things to think about.
    But don't take it from me! here's a quote from a real, live newbie:
    Quote Originally Posted by Viscouse
    I am learning buttloads just by searching on this forum. I've learned 2 big things so far: 1-it's been done before, and 2-if it hasn't, there is a way to do it.
    eegeek.net
    Newbie davucini's Avatar
    Jun 2006
    i have it, i got a combo deal from geeks.com about 3 months ago, works great, i ran it from la to lasvegas for the all star game and with music, gps, and a movie and it never messed up, and from hibernation to it being ready takes like 7-10 seconds, and i have a full install windows xp, with nothing optimized for speed or anything
    Sep 2005
    Canton, GA
    Newegg has the J7F3E-PB again...and it's cheaper now than when I bought it just a week ago...
    Get 'em while you can!!
    http://www.newegg.com/Product/Produc...82E16813153052
    <SOLD>
    CURRENT
  1. Replies: 7
    Last Post: 02-21-2008, 12:49 PM
  2. Perfect new CPU for CarPC? AMD Geode
    By Dulanic in forum General Hardware Discussion
    Last Post: 06-07-2007, 11:27 PM
  3. Audigy 2 NX software/cd?
    By Urinemachine in forum Car Audio
    Last Post: 06-14-2005, 07:49 AM
  4. Audigy NX 2 review
    By eleventh in forum General Hardware Discussion
    Last Post: 03-26-2005, 02:06 AM
  5. Amd Geode Low Power CPu
    By DaRacerz in forum General Hardware Discussion
    Last Post: 09-15-2004, 09:57 PM
