Mate it looks like a loss connection somewhere but its not in your inverter os PS.
its most likely the RCA (the plug output from your sound card) if this is loss or not well connected you will hear some crackling noises and stuff... so check that and generaly check all the connections in side your case... press the soundcard incase its not fully in its place and also check the ground to the case this also can give you this sort of problem if it has loss connection
Fosgate
LinkBack URL
About LinkBacks
