Results 1 to 5 of 5
Thread: Gigabyte GC-RAMDISK i-RAM PCI Card (Use DDR Ram as a hard drive device)
    May 2004
    Cool Gigabyte GC-RAMDISK i-RAM PCI Card (Use DDR Ram as a hard drive device)
    Hey sorry if this is in the wrong section i wasnt sure where to put it.
    I was browsing another forum and came across this pci card that allows you to install up to 4gb of DDR ram and use it as a normal hdd.
    "Through GIGABYTE's custom intelligent controller, i-RAM acts like a regular SATA hard drive at theoretically 1.5Gb/s data transfer rate. By utilizing conventional DDR memory modules, i-RAM is outfitted with four 184-pin DIMM slots that will accept any DDR DIMM and support up to 4GB unbuffered / non-ECC memory. Most of all, the major issue of data lost after powering down is solved by i-RAM's backup battery which is charged by your system on the fly. Without mechanical elements of traditional hard disks, i-RAM's stunning performance coming from the nature of DRAM as storage medium benefits in massive storage access application such as video / audio capture & editing and 3D graphics design applications. i-RAM is the fastest storage device you have ever imagined !"
    Also, if you can afford it, you can RAID more of these together to make it larger. If i had the cash, i would build a car pc and buy 2 of these things 8gb would be heaps for me
    EDIT: you have to buy the ram your self but they are cheap these days
    Apr 2005
    it's been discussed before. its more for video editing so that seek time on a HDD is null. once you're done you'll need to save it to a hdd and when the power is off your data goes bye-bye
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by kirbycope
    You can have it powered up by the battery for like 16 hours. And depending on your PSU, it may actually power the board when the computer is off.
    Apr 2005
    i hate you
    Jul 2004
    Berkeley, CA
    i hate you
    and so do the mods
  1. Hard Drive Issues in a Vehicle Computer
    By DarquePervert in forum The FAQ Emporium
    Last Post: 02-23-2008, 01:35 PM
  2. Hard drive shock / vibration thoughts
    By S11D336B in forum General Hardware Discussion
    Last Post: 09-26-2006, 11:40 PM
  3. Replies: 5
    Last Post: 04-04-2005, 03:21 AM
  4. External notebook hard drive help
    By mtmsol in forum General Hardware Discussion
    Last Post: 04-18-2002, 12:24 PM
