Motherboard Problem
I recently purchased a Cappuccino GX-1 Carputer and it works pretty good as long it's powered up. Sometimes I have to wait for 3-5 minutes until it powers up or it doesn't power up at all. I think it's the power management system on the motherboard that is not working properly. Has someone an idea what to do, where I can buy a new motherboard for the GX-1, or what other types are compatible??
By the way, has someone had the same problem too??
Are you using the motherboard in your car or at home?
I'm using the motherboard in the car with a Carnetix P1900 PSU (with ACPI). But the problem occurs also when I try it at home with the original power supply. I don't think that the operation in the car might influence or make the problem to occur, because I had the problem before I put the Carputer in the car or connected it to the PSU.
