Results 1 to 6 of 6
Thread: Theory: OEL HU Faceplates not relocatable?
    Variable Bitrate DaveB's Avatar
    Mar 2004
    I tried to use CAT 5 to relocate the faceplate on my Sony HU. The buttons all work but I get no LCD display. Others have posted similar problems with different brand HU's.
    Has anyone ever succesfully relocated a faceplate that is an OEL display faceplate? I am wondering if there is a pattern here that would tell us that the OEL displays can't be relocated/extended?
    Raw Wave EsKALad's Avatar
    Jan 2005
    Chicago, IL
    maybe a certain pin needs to be pushed in as if the face is in. when your face flips down to reveal the cd player behind it does your music still play? is the display on when the face is down? if its not on than it turns on when it pops back into place it means something needs to be pushed in so the HU thinks the faceplate is in.
    i got dat ***** sittin on 22s! SUPERMAN EDITION!
    Mar 2004
    Thanks, EsKALad.
    There is a button which operates a switch inside of the unit. Been there, done that -- its not the problem.
    I soldered it under a magnifying glass. I know everything is right.
    I'd like to get some discussion going on my theory because I think it may tell us what HU's can be extended and which can't.
    Variable Bitrate Hark's Avatar
    Feb 2005
    Atlanta, GA USA
    I tried with the Alpine CDA-9855 (not sure if it's OEL or not) and failed. Soldered it 20 times, even let a pro audio shop try, no luck.
    Aug 2005
    I did it on my CDA-9857 and it does work
    http://www.mazda3forums.com/index.php?topic=58794.0
    FLAC FC3S's Avatar
    Jul 2006
    Seoul, Korea
    well, this thread is like 10 months old.., i think the OP either gave up, or figured it out already, lol
  1. Replies: 5
    Last Post: 12-05-2005, 10:12 AM
  2. Replies: 21
    Last Post: 07-22-2005, 01:35 PM
