Results 1 to 10 of 17
Thread: Pentium M CPU Heatsink or Fan?
    Variable Bitrate DaveB's Avatar
    Mar 2004
    Het guys,
    Turns out they don't ship the heat sink or CPU fan with Pentium M processors even though the web site stores all say that it comes with a fan or a heatsink.
    So....I have to get the credit card out again. Newegg has a CPU fan that is only 25 dBA and they have a heat sink.
    What have you guys been running? Anyone have a preference or recommendation that they want to share?
    8" Lilli TS
    MB896F Mini-ITX MB
    2GHZ Dothan 533MHz FSB CPU
    1GB SDRAM DDR2 533
    Seagate 300GB SATA150 HD
    ENGENIUS WiFi MINI-PCI CARD 802.11A B 400MW OUT
    Pioneer Slot Load SLIM DVDRW
    Bluetooth V2 USB 2 Dongle
    3COM BKP Cam
    Elsewhere
    I wouldn't recommend running it without a heatsink/fan unit.
    That goes doubly so in a car where it's going to get extremely warm inside when parked on a sunny summer day.
    How about the Wiki?
    Maximum Bitrate mushin's Avatar
    Aug 2004
    SE Michigan
    No, absolutely don't run it without a heat sink and fan, but I don't think that's what he was asking about
    The products you linked to look like they'll do nicely.
    Admin
    Aug 2005
    Whether or not you need a fan will depend entirely on the airflow inside your case. If you've got good airflow arround the CPU, you should be ok with a passive heatsink. If you are unsure, get a heatsink with a fan.
    -g.
    May 2005
    San Clemente, CA
    You can get that heatsink + a fan direct from Dynatron for around $26.50 (cheaper than what Newegg is charging for just the sink). I highly recommend it! E-mail them.
    Audio: 4 * Rainbow Audio Germs + Infinity Basslink / Case: iStarUSA S3 / CPU: C2D P8700 / MB: Jetway NC64-LF / SC: ASUS Xonar Essence STX / RAM: Crucial 2x1GB 1066MHz / HD: MTRON 2.5" 30GB / DVD: Panasonic UJ-815B / PSU: Opus 180w / LCD: Xenarc 700TSV
    Mar 2004
    Wicked,
    Newegg is asking $19.99 for their heat sink with a fan.
    Most of what I have read says the Pentium M needs very little to cool it, which is why I was looking for opinions as to which way to go before I place my order. BUt I'm with you guys in that in a car environment and fan is probably the only way to go. Thanks for your opinions!
    8" Lilli TS
    MB896F Mini-ITX MB
    1GB SDRAM DDR2 533
    3COM BKP Cam
    Mar 2004
    I ordered the Heatsink/Fan and some Arctic Silver 5 Thermal grease.
    Thanks, guys. I'm stoked to get building!
    8" Lilli TS
    MB896F Mini-ITX MB
    1GB SDRAM DDR2 533
    3COM BKP Cam
    Newbie neilhart's Avatar
    Jan 2006
    Fremont, CA
    Pent. M Heatsink for MB896
    This board has space for a 50mm x 50mm heatsink with 41mm mounting hole pattern. I was put off by the price on the web for the few that met this criteria. So off to the computer surplus store and found a heatsink/fan assy for $6 that is 50x50mm with nice deep fins. Then drilled and tapped 4-40 mounting holes. Used 4-40x3/8 screws and carefully installed with h/s compund. Will RTV the screw heads before final assembly.
    Anyway, the P M 1.4Ghz hardly gets above room temp with the fan running all of the time; so have set up the BIOS to cycle the fan a 35C.
    Neil
    neilhart
    aka Neil
    My Domain is www.sfba-corvette.com check it out!
    Jan 2006
    I had problems finding a heatsink for my project so I had to make my own. Had a P4 heatsink with a 3000 RPM fan laying around that I modified. Works fine for me...
Size:  37.6 KBName:  dfi01.jpg
    Jan 2006
    Fremont, CA
    Good work backspace.
    I was prepared to do just that if I had not found a 50mm one at the surplus store. I was really turned off with the cost on the WEB plus transportation; I was going to pay in excess of $30!
    Neil
    neilhart
    aka Neil
  1. FS: Aopen Pentium-M mobo & Pentium M 1.4 cpu
    By Kalt in forum Classified Archive
    Last Post: 11-29-2005, 12:14 AM
  2. Pentium M CPU on a regular Socket 478 Mobo?
    By CJ8501 in forum General Hardware Discussion
    Last Post: 06-24-2005, 12:10 AM
  3. WTB: Pentium 4 CPU socket 478
    By Rundell in forum Classified Archive
    Last Post: 06-05-2005, 02:48 PM
  4. HELP QUICK!! CPU Fan ??
    By edrex in forum General Hardware Discussion
    Last Post: 02-26-2005, 06:05 PM
  5. Quiet CPU heatsink and fan.
    By schapman43 in forum General Hardware Discussion
    Last Post: 12-25-2004, 12:09 PM
