Results 1 to 7 of 7
Thread: CrystalFontz LCD
    Feb 2000
    Question CrystalFontz LCD
    I just got a CrystalFontz 4x20 display and am having trouble getting it to work. I've tried hooking it into the serial ports of two comps using a DB9 Female>Female connector. It sounds as if for the backlight you need to hook it up to some power, but isn't it supposed to work non-backlit with just the serial connection?
    Anyone know where I can find more info?
    GR1NCH
    GR1NCH
    [email protected]
    Nov 1999
    Sydney NSW Australia
    Post
    Check the serial cable that you are using.
    make sure its not a serial extantion.
    I might be wrong but i think those LCD displays need to have serial cables with pins 2 & 3 cross linked. Like normal serial cables.
    Fosgate
    Fosgate
    System Comp V3 - In progress.
    Low power MB with C7 CPU, DC-DC PSU, car ECU link, USB TV, GPS, 7" TFT, Wireless, Voice.
    Feb 2000
    Post
    The one I have is made by Belkin Components, it says on the box:
    Direct Cable Conection
    PC to PC File Transfer.
    DB9 Female/Female
    SERIAL
    Is there anyway I can test to see if the cable is the problem?
    GR1NCH
    [email protected]
    Dec 1999
    st. louis
    Post
    I had problems with my Belkin serial DB25 cable for my LCD. Nothing would show up. As soon as I switched to a non-belkin cable...all was good. Sounds like you might need to try the same thing. Mine said it was for PC to PC also.
    [This message has been edited by Old El Paso (edited 03-10-2000).]
    Feb 2000
    Post
    Cool, thanks for the advice. Its nice to know its most likely not my lcd.
    GR1NCH
    [email protected]
    Feb 2000
    Edison, NJ
    Post
    you have to be careful which cables you buy .. some are straight-through, others are null-modem or crossover cables.. just get a db9 extension cord and a gender changer (i'm using a pic-an-lcd module so i dont need the gender changer.. the connector is female on it)
    Feb 2000
    Post
    so the gender changer wouldn't cause any problems... I had bought an extension in case the male-male wasn't long enough, so if I just needed a gender changer it may save me some time.
    Gr1nch
    GR1NCH
    [email protected]
