Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: PC shuts down in the middle of resuming hibernation
  1. #11
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    I run into this problem with my desktop at home.
    Here is what happen.
    - The PC hibernate fine when I either Start -> Shutdown -> Hibernate or Push that power button.
    - When resume, the process bar goes to about 99%, PC shutdown.
    What I found out is that the OS HD is on Primary Slave (as it was a slave drive before).
    Fixed that master/slave jumper and the PC hibernate fine for "couple times".
    Now there is a diffent problem.
    It doesn't came out of hibernation. After the process bar complete and the background image show with working mouse but nothing else. Sometime only a working mouse with a grey background. And this is a spanking newly formated HD with only XP and Firefox.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  2. #12
    May 2006
    Wow... thanks matrix.. I had 1 hd on the cable select jumper. I changed it to be pri. master and that did the trick.. well for now its hibernating and restarting just fine. I have yet to experience the second problem that you are encountering about the unable to hibernate. Ill let you know if that starts happening to me. But thanks!!!
  3. #13
    Variable Bitrate Redian's Avatar
    Apr 2006
    Connecticut, USA
    matrix, i can tell you with 99% accuracy that it is a driver problem... maybe not video (since it shows up), not mouse (it works), so check other stuff...
    like sound, try playing somhting then hibernating and see if it plays when you turn it on.
    another thing it could be is the keyboard, take that off and go into hib, if it STILL has that problem, update the video/sound drivers as well and if its still around.. do wifi/lan/all other drivers
    2004 Impreza WRX CarPC Install
    I am willing to host any legal downloads that may benefit the CarPC community - PM for info
    "When you go 0-60 in 4.5 seconds, you don't need a made up character called fast. Thats what makes a Subaru, a Subaru."
  4. #14
    Constant Bitrate gokee2's Avatar
    Feb 2006
    B.More, MD
    I'm having this issue as of last night. I was able to do hibernate and resume in less that 10 seconds. All of a sudden, I get that "The Last attempt to restart the system..." s**t error. I can not select any of the 2 options as the keyboard (USB) goes dead cold after the BIOS info screen. I tried hitting F8...that doesn;t work either. I have a power brick I made, which I will try the moment I'm done typing. I will check for drivers and I pray its not the HDD. I did do a quick format though on installing windows. (Lord, please help me on this one). :'(
    [HL]My Worklog (~75% complete, but fully functional)[/HL]:
  5. #15
    Feb 2006
    B.More, MD
    I must report...SUCCESS!!! PS/2 keyboard did the trick. I thing I messed with the settings for USB in my BIOS, but I picked option 1 to "Delete..." and it took me straight into windows. Option 2 DID NOT work for me. I guess having a PS/2 keyboard will avoid hustles. so my problem solved.
  1. PC audio too low
    By Alphared in forum General Hardware Discussion
    Last Post: 10-04-2008, 05:20 PM
  2. For Sale for all you aussies. Complete mp3 car pc
    By Holden__V8 in forum Classified Archive
    Last Post: 04-09-2005, 06:30 AM
  3. A few observations in OS and why I'm now using Windows 2003...
    By Mastiff in forum Software & Software Development
    Last Post: 01-21-2004, 10:11 AM
  4. evaluate this in-dash tablet PC plan
    By dimas in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 11-15-2003, 07:50 PM
  5. FS: Casio EM500 Pocket PC / 800mhz Desktop PC / Misc
    By gguy in forum Classified Archive
    Last Post: 10-07-2001, 09:00 PM
