The supply in the NiteMax will handle a wide range of voltages out of necessity. (The battery voltage itself changes as it becomes discharged.) It behaves more like a constant-
power load in as much as it will pull current based on what it needs from the voltage you provide. In other words, at lower voltages it will pull more current and at higher voltages less -- the power consumed will tend to remain the same.
I have looked a little bit at the power supply and I'm convinced that it can handle voltages up to about 13 Volts. Beyond that, funny things can happen and I haven't given too much thought to the ramifications. (Your car is closer to 13.8 volts while the engine is running and this is just too much for me to be comfortable with right now.)
So yes, 12 Volts from your computer power supply should be just beautiful.
