BTW, Sound card's output is line out.
Quote:
Originally Posted by 95m3hotness
I installed windows and plugged a speaker into both ports and no sound.
It's a line out, therefore you would need amplified speakers.
Considering I wanted to use the USB powered 'analog' speakers with the motherboard's sound chip, an outboard sound card was not an option for me. There are only a few USB ports on the board and I did not want to have the outboard sound card.
I'll probably end up going with an ITX P4 or P4-M.
My use was not specifically for a car, it's a tiny computer for a specialized network monitor environment.
I happened to stumble onto this place when doing research on ITX machines and this motherboard model.
Sometimes you hear some sound.. Sometimes you don't...
so the line out cannot just be hooked up to a speaker or even headphones?
Depends on the card itself, Sometimes the output is not loud enough to drive speakers. Sometimes it can do speakers or just headphones.
On my Mobo, I did not get output with headphones (amplified or not), nor amplified speakers.
Cause i tried both and i got no sound. i hooked up my soundcard from my desktop computer into the pci slot and it works perfectly.
This was my finding also.
I even installed the Freetech sound drivers.
Although it looks like a commwell board too.
I may try and get the commwell drivers and see what happens.
