never mind guys i figured out the problem myself.
Hey i guys, i have a problem with my motherboard.
I have a Freetech p6f135 mobo with 512 ram and a pentium 3 intel processor.
When i first power up the motherboard, it runs but it doesn't send a signal to my monitor.
So... I resart it and then my monitor gets a signal but the motherboard shuts off after about 1 second of loading.
It just does that. no signal: Signal then dies: and i can never get it to load.
I have tried 3 different powersupplys with no luck. And i have also tried different ram (the 512 it came with and a 256). with the same results.
I hook up the powersupply and ram and monitor. i have also tried it with a hd attach.
Can someone plz help me.
So what was wrong?
Where did you get your MoBo?
Was it from a malltech on eBay?
I just purchased 2 of them from the seller and they both have issues. *sigh*.
Board 1.
Would not post when memory was set to 133MHZ.
Took me a while to figure it out. Worked when memory was forced to 100MHZ. it's not a memory or CPU issue. (as I've swapped both). it's a board issue. Also the sound chip was NOT DETECTED.
Board 2.
Posted, Ran fast and stable until I began using the USB ports. When I did a hot plug the board would loose power and become unstable.
The sound chip was detected but I could not get sound out of the board no matter what I did. I tried Linux, Windows and even downloaded the drivers and installed them too. Nada.. keep in mind the OS's believed the sound chip was there and acted fine. I could'nt even get cdaudio out of it (with either os). Therefore I suggest you test it all out very well.
The seller did allow me to send them back for a refund.
Frankly if only 1 had trouble I would have kept the other.
Mine runs at 133mhz and it registers the sound card also, i havent tried the usb ports though, i will give them a try, as for the sound card/chip, hopefully it works. I installed windows and plugged a speaker into both ports and no sound. If theres no sound it wouldn't be a huge problem, because i plan to get an external soundcard anyway. What did you plug into the usb ports to test them?
I hot plugged a couple of things and it seemed as if there was a huge drain of power. The motherboard's power would dive. Sometimes it would come back and other times it would not.
I tried with the following.
1. A USB Key with a compact flash slot.
2. An external floppy that also has a 8in1 card reader.
3. A regular USB floppy.
4. USB powered analog speakers.
With each one, when I hot plugged it, the motherboards power dived. If I booted with them it was OK.
The external floppy & 8in1 card reader combo would not work at all.
It's a line out, therefore you would need amplified speakers.Originally Posted by 95m3hotness
Considering I wanted to use the USB powered 'analog' speakers with the motherboard's sound chip, an outboard sound card was not an option for me. There are only a few USB ports on the board and I did not want to have the outboard sound card.
I'll probably end up going with an ITX P4 or P4-M.
My use was not specifically for a car, it's a tiny computer for a specialized network monitor environment.
I happened to stumble onto this place when doing research on ITX machines and this motherboard model.
so the line out cannot just be hooked up to a speaker or even headphones? Cause i tried both and i got no sound. i hooked up my soundcard from my desktop computer into the pci slot and it works perfectly.
Depends on the card itself, Sometimes the output is not loud enough to drive speakers. Sometimes it can do speakers or just headphones.Originally Posted by 95m3hotness
On my Mobo, I did not get output with headphones (amplified or not), nor amplified speakers.
This was my finding also.Originally Posted by 95m3hotness
I even installed the Freetech sound drivers.
Although it looks like a commwell board too.
I may try and get the commwell drivers and see what happens.
