Results 1 to 9 of 9
Thread: Networking PCs
    Emo
    Emo is offline
    Nov 2005
    Orlando, FL
    Question Networking PCs
    Ok.. I'm usually good at this but for some reason for the life of me cannot get this to work
    here's the deal:
    I have 3 PCs (including the carPC) all setup in my room...
    My main PC (M)
    My Laptop (L)
    and Carputer (C)
    I want to network the main pc and the carputer so I can transfer all the stuff that I've collected for the carputer from my main PC but for some reason they wont talk to each other.. this is how it's working now:
    M works with L
    L works with C
    C does NOT work with M
    I don't feel like transferring everything to the laptop and then again transfer it all to the carputer(around 20GB worth of stuff).. any ideas?
    Thanks..
    Feb 2004
    Green Bay, WI
    is this all on a wireless network??? do you have file sharing setup???
    Dec 2005
    UK
    Yeah I instantly see the problem - it doesnt work.....
    Think it could be a plan to post some info such as:
    OS of machines, type of network, (if wireless wep, wpa?), are you using static or dynamic IPs, are you using simple file sharing?
    How are you trying to connect to the machine, UNC? mapped drive? Are you using an IP or going by a name?
    What exactly is the problem, what error comes up.
    Might help methinks
    '76 LR Series III 109 - Fully Sorted
    '95 Rover 620ti - Working on it
    A cynic is what an idealist calls a realist
    Emo
    Emo is offline
    Nov 2005
    Orlando, FL
    Heh... Sorry for being so vague
    Here's some Info:
    Main PC is XP Pro SP2
    Carputer is also XP Pro SP2
    Laptop is XP Pro with SP1
    I have a Linksys router (wired/wireless)
    The main PC is hard wired to the network and the laptop and the carputer are wirelessly connected (Not sure about the WEP or WPA part). I'm using Dynamic IPs assigned by the Router itself. So The main PC is usually 192.168.0.101, then 102, 103 and so on. I think filesharing (printers) is off.
    The way I usually try to connect is go to the network connections and on the left there is that option "setup a home or small office network". I pick the way the pc is connected (internet> Router> PC) and then I assign all 3 PCs to HOME domain. At the end I just go to the "View network computer" and then I pick the one I need... but when I try to access the pc it says I dont have permission to go there or the path was not found"
    I hope this explains a bit more!
    ITL
    ITL is offline
    Maximum Bitrate ITL's Avatar
    Jul 2004
    Atlanta, GA
    try using the UNC path with the ipaddress...
    In the address bar of Windows Explorer, try typing "\\192.168.0.102\c$" and see if you can see the root drive of the machine with IP *.102...
    Do the same for the others.
    option 2:
    right click a folder and set it to be Shared. If you allow access to other users, you can write to it from another machine. Try that on all 3.
    CarPC #3: 99% Complete
    Pentium M 1.7Ghz, 1GB DDR2 RAM
    DVD/CD-RW installed in dash below monitor
    OEM LCD relocated for 7" Touchscreen
    Wi-Fi, GPS, PS2 controllers...
    500+ full albums
    4,000+ video games
    music videos, movies, & more!
    old carPC
    It ain't easy being a green moderator meddler's Avatar
    Aug 2002
    Steps out the front of Henson's workshop or Sydney
    try turning on sharing on all the computers.
    Elsewhere
    1) Make sure all computers are all on the same subnet. usually, you're going to have an IP address of 192.168.1.x and a subnet bask of 255.255.255.0. That means that any IP address of 192.168.1.x will be able to see and communicate with any other with the same IP address scheme.
    (Note: There are ways to alther this to allow a larger or smaller subnet, but that's a more detailed discussion than is required here.)
    2) Make certain all the computers are members of the same workgroup. If they're not in teh same workgroup, it makes locating the computer more difficult. For a home network, there's no need for a domain. If there is a need, then you probably know what you're doing anyway, so this simple tutorial is useless to you.
    3) Turn on filesharing for computers that have files you want shared, and only share what you want shared. Don't share the root of your C drive because you can. It's a dangerous proposition.
    4) With Win2000 and/or WinXP, make certain that you have a user setup with the same password you use to log into your computer. You're logging on as Administrator you say? You should be smacked until you bleed. For example, I have users on my server for Darque Pervert, Kelly, and John. One is a login in my gaming computer (this one), one is from my work computer and one is my girlfriend. Also, ont he computer(s) with shares, make certain that the users (or a group that the users are a member of) have appropriate access to the shares.
    How about the Wiki?
    Unregistered User ODYSSEY's Avatar
    Feb 2001
    Raleigh, NC USA CarPC Ver3: [▓▒▒
    Number 4 is important with XP.
    ODYSSEY
    Quote Originally Posted by Tidder View Post
    Digital-Car UK|
    (\__/)
    (")_(")
    Emo
    Emo is offline
    Nov 2005
    Orlando, FL
    well well well.. fnally I got it! Thanks a lot guys! Much appreciated!
    -Emo
  1. FS: 2 LCD Monitors, 2 PC's
    By fventura03 in forum Classified Archive
    Last Post: 10-18-2005, 07:32 PM
  2. HP Embedded Thin PCs.....
    By camsgs3 in forum General Hardware Discussion
    Last Post: 03-31-2005, 02:06 AM
  3. Confused about shuttle PCs vs via processors
    By clean customs in forum Newbie
    Last Post: 03-04-2005, 10:13 AM
  4. wireless networking
    By snakebite in forum Media Engine
    Last Post: 07-19-2004, 01:20 AM
  5. I want more cool stuff in my car. (wireless networking)
    By LoreleiGuy in forum General Hardware Discussion
    Last Post: 02-27-2000, 03:07 PM
