Results 1 to 7 of 7
Thread: CCD Infrared Rear View Camera Review???
    Variable Bitrate ramy_zohair's Avatar
    Sharjah, Emirates
    Arrow CCD Infrared Rear View Camera Review???
    does anybody have the new night vission camera from MP3CAR store:
    http://www.mp3car.com/store/product_...a61a0028ebd855
    I want to see some kind of review on it, shots taken in day, & night. Can't seem to find any except those on ebay. (I guess its from the supplier so I think it would be biased).
    Anybody got it??
    Sharjah, Emirates
    Nobody having it???
    May 2004
    Denver
    I have a camera that is similar in setup and cost WAY less... I have hooked it up but do not have it installed permanently - it is on the to do list...
    what are you wanting to do with it?? it will not "light up the night" for KnightRider like nightvision... to do so would require some intense IR lighting... also, I would think that you'd want it behind the windshield wipers so that it had a clear face....
    mine is for backup purposes only and it is more than capable of that...
    EPIA SP13000, 512 DDR400, Seagate 300GB, Belkin PCI 802.11g w/external antenna, Holux GM-210 GPS, XM Direct w/ serial, Dlink FM, Opus 120 p\s, Rockford P4004 amp, Xenarc 7" VGA touchscreen custom mounted in double din spot -- see pics and write up here!!
    Sharjah, Emirates
    I need it for backup purpose only too. I just want to see the quality of its shots. At day, night, colors, resolution.... and so on.
    May 2004
    Denver
    the daytime is color, and as the darknes sets in the color gets removed so it becomes black and white... there is a small photocell in the unit that determines the brightness, so it isn't a color-daytime and b&w-nighttime setup... it is more like a full color in the day slowly blended into b&w at night...
    Low Bitrate grimor2000's Avatar
    Dec 2005
    Chicago-ish
    you can get the same ccd in a much cheaper camera. The resolution is as good as any normal cam-corder.
    Causa latet vis est notissima
    VIA SP13000
    1GB DDR400
    Slimline Slot-load DVD-RW
    60GB 2.5 Inch SATA 5400RPM
    Dual Active PCI riser
    PCI TV/FM card
    Logisys FP800
    Thermaltake VFD Media Lab
    M1-ATX
    _
    Mar 2004
    Little Elm, Texas
    Quote Originally Posted by grimor2000
    do you have any links to cameras that you are referring to by chance?
    Jan Bennett
  1. [REVIEW] In-Bumper Rear-view camera
    By RoyN in forum General Hardware Discussion
    Last Post: 12-30-2006, 03:42 PM
  2. Replies: 8
    Last Post: 06-21-2006, 08:28 PM
  3. 120 deg Wide-Angle Rear View Reverse Camera off Ebay - REVIEW
    By tbird2340 in forum The Review Palace
    Last Post: 01-11-2005, 04:30 PM
  4. rear view camera
    By lasteclispe in forum LCD/Display
    Last Post: 10-21-2004, 11:00 AM
  5. Have video camera for rear view - which program?
    By nxt125 in forum Software & Software Development
    Last Post: 08-15-2002, 12:25 AM
