hmmmmm
I have an M1-atx with a SP13000.
When opperated just by the acc wire for the shutdown/start up controller on the M1, it works fine. And I can shut it down by pressing the power button hooked up to the M1 or to the MoBo. BUT, the power button will not turn the comp back on after it is shut down until I disconnect and reconnect the Acc power. and the reset button does not work at all. I am sure I have the correct wires hooked to the right jumpers on the board.
Any other suggestions?
Causa latet vis est notissima
VIA SP13000
1GB DDR400
Slimline Slot-load DVD-RW
60GB 2.5 Inch SATA 5400RPM
Dual Active PCI riser
PCI TV/FM card
Logisys FP800
Thermaltake VFD Media Lab
M1-ATX
hmmmmm
VIA SP13000
1GB DDR400
PCI TV/FM card
Logisys FP800
M1-ATX
