Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
Thread: Too many USB devices
  1. #21
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    ner ner DP, i am better than you! :P
  2. #22
    Maximum Bitrate Dragonknell911's Avatar
    Aug 2004
    Haha, Scouse Monkey thank you for your help too =)
    edit i also have a usb num pad for dialing phone numbers.
    REBUILDING!!
  3. #23
    Low Bitrate grimor2000's Avatar
    Dec 2005
    Chicago-ish
    when you explain to me how you will ACTIVELY use all of those usb devices (not just all plugged in) at the same time, I'll believe you
    Causa latet vis est notissima
    VIA SP13000
    1GB DDR400
    Slimline Slot-load DVD-RW
    60GB 2.5 Inch SATA 5400RPM
    Dual Active PCI riser
    PCI TV/FM card
    Logisys FP800
    Thermaltake VFD Media Lab
    M1-ATX
  4. #24
    Aug 2004
    Seriously i'd appreciate the help, if you'd bother to read first. Oh and not post unintelligent and random things such as,
    Quote Originally Posted by grimor2000
    bluetooth is your friend lol
    Quote Originally Posted by dragonknell911
    Earlier in the thread, i specify exactly what devices will be used at all times.
    which would be...
    Quote Originally Posted by Dragonknell911
    I will be using the dvd drive frequently and the webcams and cf reader constantly
    REBUILDING!!
  5. #25
    Feb 2006
    WTF, I thought I wanted to put a lot of things on mine.
  6. #26
    Aug 2004
    This really is'nt that bad, I was simply looking for the simplest way to get these powered/ and connected. Which i've found. Thank you Scouse Monkey, and DarquePervert.
    REBUILDING!!
  7. #27
    Dec 2005
    Chicago-ish
    which would be...
    well, that covers maybe 3 or 4 devices, that doesn't include all 15. And I answered your question as soon as you asked but since you have some kind of self-inportant attitude, I'll make sure I don't answer any moreof your questions because obviously I can't read, and you can't think
    VIA SP13000
    1GB DDR400
    PCI TV/FM card
    Logisys FP800
    M1-ATX
  8. #28
    Mar 2004
    Bristol
    no probs. good luck.
  9. #29
    Variable Bitrate ramy_zohair's Avatar
    Sharjah, Emirates
    good luck with that list.
    Final Touches
    Car: 2002 Mitsubishi Magna EI
    CarPC: SP13000, M2-ATX, 512 MB RAM, 120 GB 2.5" HD, X-Fi Sound Card, Xenarc 700TSV, Garmin 18 USB.
    Audio: 2X15" Rockford Punch Z, 1 Rockford Punch 2-ch Amp, 1 Soundstream Lil Wonder II 4-ch Amp
  10. #30
    FLAC LESLIEx317537's Avatar
    Jan 2002
    Long Island, NY
    I made molex power extension cables.
    One runs to the front of the car, one to under the back seat.
    All my devices are powered using molex connectors. I just buy Molex power splitters each time I add a device.
    One 4-port hub in back, two 4-ports in front (Got a 7 port Belkin waiting to swap).
    I power everything off the M2-ATX in my sig with no problems.
    SP13000|M2-ATX|512MB DDR400|2.5" 7200RPM S-ATA|Trans-7"|Slim SL DVD-CDRW|KEH 5.1 DSP|SB L!ve Ext|Gyration PowerMate|BT|WiFi|GPS|WinXP|VoomPC
    GPSing - Digital Speedo
    Relocating headunit and extending faceplate
    Button app to Alt-Tab between two programs
  1. My USB/Wifi troubles.
    By JPuma in forum General Hardware Discussion
    Last Post: 09-23-2005, 12:44 PM
  2. Am I exhausting my USB inputs? How many devices is too much?
    By ummagawd in forum General Hardware Discussion
    Last Post: 04-05-2005, 02:46 PM
  3. Audio crash after hibernate (USB alerts)
    By Peoples in forum RR Bug Tracker
    Last Post: 03-10-2005, 02:29 PM
  4. noise from usb devices on M10K
    By port20 in forum General Hardware Discussion
    Last Post: 04-19-2004, 09:07 PM
  5. Replies: 4
    Last Post: 04-06-2004, 10:52 AM
