Results 1 to 10 of 16
Thread: My Aopen Pandora Just arrived!
    Feb 2006
    Hello all,
    My pandora just arrived and boy is it small. I have about 75% of the stuff I need to set up the carputer. I'd set it up now, but my CPU is in transit. I still need a Mini PCi Wifi card, USB hub, USB soundcard, and various cables.
    Hopefully I will get this thing set up sometime next week.
    Best regards,
    Marc
    Dec 2005
    Good to hear. I agree, the Pandora is incredibly small...even smaller than I expected. Its size makes it easy to fit into creative places in your car! I'm going to flush mine into the lower dash area of my civic.
    You should start a worklog so we can track your progress!
    Feb 2006
    Wish my CPU was here allready!
    Hey Quack,
    I just checked out your worklog and it looks as though our carputers will be similar, although the mounting different since we have different cars.
    I have a 2005 Mazda 6 Wagon and I intend to put the Pandora in the armrest center console where a cargo space is. The Pandora will fit in there perfectly, but I need to remove the current internal box that is there since it is sloped where a Power socket is. I will remove the center console and remove this plastic housing and replace it with a way to hold the Pandora as well as make it removable if I ever decide to use it elsewhere in the house or for updating.
    My screen will go in the map pocket on the dash and I intend to automate it to open and close and reveal the screen.
    I plan to use my stock head unit rather then a new install at the moment. I want the car to look stock from the outside. I am sure I will be giving up some audio performance with the stock radio, but it sounds pretty good now so hopefully I wont get the bug to change it too.
    Good luck and i willmonitor your progress since I figure we both will be running into the same hardware software issues as we progress.
    Good luck,
    Marc
    Registered User InHoc's Avatar
    Feb 2006
    Alabama
    Congratulations to both of you - I'm hoping to be another Pandora member in a few days. My question is this - I'm sure both of you read Kalt's thread on his Pandora setup, so what are each of you planning to do with the problem of displaying 800x480 resolution with the chipset on the MB? I think a few people just deal with slightly distorted screens... Or do you all know of a way to make it work?
    Thanks!
    Dec 2005
    Don't know yet what I'm going to do about the resolution. I want to get everything setup and see the issue for myself before I tackle it. I should see it for myself over the next day or two. I got the PC up and running with windows installed last night. When my wireless card gets here later today I'm going to install the touchscreen drivers and get the 7" lilliput working with it.
    On a side note, I can see how the little blue power/activity light on the front of the box is going to be annoying. The light itself won't be the problem...it's going to be annoying when a girl gets in the car and goes nuts over the "cute little blue light" instead of the carputer install . I used to have a GTI VR6 with all the bells and whistles and the only thing they could find to say about it was "the blue lights (on the dash) are so pretty".
    Feb 2006
    Hey Quack,
    Great to here you got the computer up and running. I am still waitong on my CPU to arrive in the mail. Some ebay vendors blow for communication. I hope itarrives this weekend.
    As to the display issue, the only problem I had with the pandora was the fact that you could not get 800x480. Althogh the pandora did everything else I wanted and then some for less then a via SP13000 setup. I figured the only downside was still worth it and Kalt said it looked fine on his screen. He also said many people have been pushing for drivers to get the 800x480 that I asume it will arrive in the future.
    Did you get the aopen Wifi card or are you planning to use a USB wifi?
    Keep us updated on your progress.
    Marc
    Variable Bitrate kamikaze2112's Avatar
    Feb 2005
    Barrie Ontario
    do you happen to know what slim slot load drive it's using? (make/model)
    Dec 2005
    I got the Aopen Pandora wireless kit which is a miniPCI card and an antenna. Should show up on my doorstep today. I got it from excaliberpc for $39. Looks like they raised the price a buck or two.
    Don't know about the make/model for the optical drive.
    Nov 2005
    Hey there thrmaln, I have a Mazda 6i. I know exactly where you plan on placing your Pandora box.
    Hey, let me know how hard or easy it is to remove the plastic storage console. Pics would be great.
    So question, if there is already an existing 12v cigarette lighter in the center storage console couldn't I just tap into it with a Carnetix P1900?
    Feb 2006
    Hey Yamamotosama,
    I plan to set up the carputer on the bench and get it fully working before I instal it in the car so it may be a few weeks before I tackle the car instal. As for the cigarete lighter in the pocket, yes there is one on mine. Does your 6i have one? Anyway, I am unsure if it has a connection that is on all the time or with the key. I believe it is on all the time since it is for an accessory rather then a lighter. Either way, if thee is room I plan to tap into it there. I need a connection of on all the time and keyed only so whichever it is not, I will find under the dash.
    I plan to tke pictures of everything i do as well as make brackets to hold everything.
    I wil start a worklog soon and you can monitor it to track my progress.
    Best regards,
    Marc
  1. 2001 Honda Civic Aopen Pandora MiniPC
    By Quack in forum Worklogs
    Last Post: 07-23-2010, 04:01 AM
  2. Replies: 8
    Last Post: 09-17-2006, 12:51 PM
  3. FS: Aopen 915-B Pandora miniPC small NEW in box
    By kickercivic1 in forum Classified Archive
    Last Post: 02-21-2006, 07:55 AM
  4. Aopen Pandora MiniPC (Full System) and Carnetix P1900 P/S
    By cybrchaddy in forum Classified Archive
    Last Post: 02-20-2006, 01:57 PM
  5. Aopen mini ATX PSU !
    By Avner in forum Power Supplies
    Last Post: 03-04-2004, 10:53 PM
