Results 1 to 10 of 18
Thread: M10000 VGA problem
    Feb 2006
    M10000 VGA problem
    I purchased a via M10000 motherboard and when i first hooked it all up in my room it worked fine the display was a little choppy but whateveer moving on anyway i unhooked everything and it all sat in a box for about a week then last night i put it back together and now the monitor cant pick up a signal from the motherboard. and not even my 8' monitor my 19' monitor cant pick up the signal either. is there somthing wrong with my mother board? i dunno if its happened to other people but this is kinda ****ing me off
    Variable Bitrate kmcniece's Avatar
    Aug 2004
    Portland, Oregon
    Did you change the bios settings?
    Do you see anything at boot?
    You can always reset the bios by following the instructions in the manual. If you changed the BIOS settings for display type, it will drop signal to the VGA.
    (if you changed it to TV or LCD, or something like that...)
    EPIA M10000, 512 Ram, Opus 90, GPS, XM, 7" Xenarc, Pioneer HU
    Status:
    Installed & Working....
    Custom enclosures
    Newbie Guide
    Feb 2006
    I cant see anything at all everything is getting power just when the monitor turns on it just says no signal. i cant even view the BIOS setup or anything actually
    Feb 2006
    If i bought a video card would that work?
    Low Bitrate susuking's Avatar
    May 2005
    SoCal
    that is wierd, try clearing the bios, see if that helps, or maybe it was broken while in storage? try a video card, see if that do anything,
    Progress Bar: [//////////]100%
    Have M10000, 40gb 2.5"hdd, i guidance, wireless,slim slot drive, delorme gps, roadrunner, liliput touchscreen, opus150w ...
    all fabrication done...
    Aug 2004
    Portland, Oregon
    It has the symptoms of a bios setting.....
    I would try the BIOS reset first.....then go second Video card and see what happens.....
    Did you buy it new?
    Status:
    Custom enclosures
    Newbie Guide
    Feb 2006
    yup bought it new from mini-box.com i mean it worked great before the onboard video kinda sucked though it wouldnt suppourt 640x400 res at 60ghz to well but whatever i guess i need to try the video card because i cant see anything on the screen to begin with
    May 2005
    SoCal
    try ^^ what he said, see if it does help
    Feb 2006
    i cant see the BIOS screen i cant see anything
    Elsewhere
    Try a new VGA cable. Check all your connections.
    If not, I'd think it's something internal to the monitor. I can't help you troubleshoot that, but there are other members who can.
    How about the Wiki?
  1. Replies: 7
    Last Post: 02-21-2008, 12:49 PM
  2. Xenarc Problem or Polarity Problem?
    By mbkowns in forum LCD/Display
    Last Post: 01-06-2007, 09:57 PM
  3. Difference between VGA and Non VGA Screens??
    By sould in forum LCD/Display
    Last Post: 11-25-2005, 11:09 PM
  4. Epia M10000 VGA problems
    By Dluvr22 in forum General Hardware Discussion
    Last Post: 07-10-2005, 07:38 PM
