Results 1 to 10 of 11
Thread: PC shut off on it own
    cyn
    cyn is offline
    Feb 2006
    Iíve bought a new computer recently. But after a month, it starts to have problems. It shuts off automatically after I turn it on for just a while (less than 15 minutes), which I donít think would be due to overheated. Then I try to turn it on again straight away but it did nothing. So I wait for a few minutes (try unplug and plug in the power point) and try to turn it on again, it gets back to work again as normal start up (without stating improper shut off or anything). It has happened twice since last week, and always happens within the first 15-30 minutes of start up. Any one can help me, pls. Thanks
    Variable Bitrate nkotch's Avatar
    Dec 2005
    FL
    I'd first try to replace the power supply, or just borrow a known working one and try that.
    Nick
    '99 Ford Escort ZX2 CarPC <-- RIP Feb '07
    2006 Chevy Equinox LS (Current Project)
    **VIA EPIA PD 1ghz Mobo, OPUS 150, 7" LinITX LCD touchscreen, 512 Ram, 60Gig HD, DLink Bluetooth, Belkin 802.11g wireless,
    FLAC Jahntassa's Avatar
    May 2005
    Conyers, GA
    What kind of computer is it? Manufacturer / model? Or any details? I know some Dells have issues like that.
    cyn
    cyn is offline
    Feb 2006
    Here is my configuration:
    CPU: Intelģ Pentiumģ 4 processor 630 supporting Hyper-Threading Technology
    Motherboard: ASUS P5PL2 Intel 945PL
    Display card: Grandmars ATI Radeon X700 PCI-E 256Mb
    Ram: 512Mbx2 NCP DDR PC2 4300 NC00164
    Hard drive: WD 1200JS SATA 120GB
    DVD: NEC DVD RW 4X
    Power 480W
    Itís not a brand computor.
    Elsewhere
    I think it is shutting down due to overheating.
    How about the Wiki?
    May 2005
    Conyers, GA
    Yeah, check to make sure all the fans are spinning. There should be at least two, one in the back of the power supply (or somewhere on it) and one on the processor. Hopefully there's more than that, but make sure they all work.
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    you might check event viewer for error messages. (assuming you are running a windose OS)
    TruckinMP3
    Read the FAQ!
    cyn
    cyn is offline
    Feb 2006
    I wouldn't think it was due to overheat, since it usually happens within the first 15 minutes after itís on. Could that be heated up to such a high temperature within just 15 minutes? Also, why I canít turn it on straight after it shut off automatically?
    There have two fans both are running. But I heard some weird spinning sound from the fan located somewhere at the back of the power supply, especially when I am re-plugging my keyboard (PS2). Is that normal that you will got weird spinning sound if you press somewhere around there?
    I'm using window XP, so how can I check event viewer for error messages? Can you show the routines? I would be greatly appreciated.
    Honestly Iím also suffering another problem. When I am working with a few workstations (such as transferring file from folder to folder, with the running of RealOne and ACDSee), all of a sudden, all the workstations, toolbar and even the icon on desktop are disappeared (only the wallpaper was left on screen). After a few seconds, toolbar and icon come back in but all the workstations are closed. All my work are unsaved and lost. What problem actually is? Software or hardware? Is it related to my computer shut off problem too?
    Elsewhere
    Quote Originally Posted by cyn
    It doesn't take long for a CPU to get to the overheating temperature. That's why you put on a heatsink/fan combination.
    If the CPU overheats, it won't turn on right away because thermal protection circuitry prevents it from coming on until it cools down.
    Spinning isn't a sound. The moving air makes a sound. The vibration of the fan makes a sound. The rubbing of fan blades on something makes a sound.
    You need to have at least three fans in any new system. All fans should move a substantial amount of air.
    One fan should be in the power supply blowing hot air out of the power supply. This isn't so much for cooling the system, but for cooling the PSU itself.
    One fan should be on the CPU itself, integrated with a heatsink. The fan should blow air down into the heatsink to force colder air across the heatsink and take warmer air away. The heatsink should be in contact witht he CPU, with some thermal transfer material (a thermal pad or thermal compound like Arctic Silver) between the heatsink and the CPU itself.
    One fan should be at the rear of the case near the CPU blowing hot air out of the case.
    The general theory is that you want to draw cold air in from the bottom front of the case and exhaust hot air out the upper back of the case. It creates a consistent windtunnel effect, so there's air moving consistently in the same pattern throughout.
    It could very well be related to your computer shutoff problem. It could also be related to a number of other issues, as well. Solve the overheating problem first.
    How about the Wiki?
    cyn
    cyn is offline
    Feb 2006
    I found a bunch of wire was actually rubbing the fan blade when the fan is on, so I relocated it and my PC works pretty well (without shutting down) for a while. But until yesterday ďshutting downĒ was happened again and pretty frequently, three times within an hour. I found that I couldnít get it start up again unless I turn the main power off and on again. When the computer shuts off, the monitor was no display, but ďNum LockĒ on keyboard was always on.
    A new problem comes in last month, I experience twice of having computer on but without display on monitor. When I start up my PC, the hard drive was on running (green light is on) but without display (might not boot up) and I re-boot it and it works again (pic comes out). Whatís matter is it? It keeps on having trouble. Help!!!!!!!!! please!!!!!!!!!!!!!
    Refer to the fanís question, Iíve found another fan the display card, so it is three in total, another two are on CPU and in the power supply. My friend told me it should not be the overheated problem, since Iím using the largest case, which provides better cooling, and also my sister has the same hardware configuration as mine except with a better display card, but she does have the same problem as mine.
  1. How2 control CarPC from key fob....
    By NotchbackVW in forum Power Supplies
    Last Post: 09-21-2007, 05:27 PM
  2. ONINE PETITION: TomTom Navigator for PC
    By bLindmOnkey in forum GPS
    Last Post: 06-07-2007, 01:16 PM
  3. Turn the pc on from the boot
    By NiN^_^NiN in forum General Hardware Discussion
    Last Post: 08-05-2005, 11:42 PM
  4. Replies: 21
    Last Post: 07-22-2005, 01:35 PM
  5. PC / Vehicle interface
    By bluelip in forum General Hardware Discussion
    Last Post: 07-15-2005, 01:24 PM
