Results 1 to 10 of 10
Thread: what is the name of this usb wire?
    Variable Bitrate 0okami's Avatar
    Feb 2006
    USA
    Well, Last night I was looking around for a usb extension wire to connect my LCD from my dash to my trunk... I need about 15 feet (4.57200 meters).
    Attached are the images of a wire i have which seems that will do the job, but its too short. When asking for this wire, what is the proper name?
    Also, can this be made out of cat 5? I have lots of cat5 laying around with no use. Im sure I could solder the wires on to a connector. but I wonder if there would be signal issues and such...
    hmm...
    ~0okami.Digital
    Variable Bitrate kamikaze2112's Avatar
    Feb 2005
    Barrie Ontario
    it's just a usb extension
    Feb 2006
    USA
    i'm thinking its "a to a extension." Is this correct?
    ~0okami.Digital
    Variable Bitrate Freelander's Avatar
    Jul 2005
    NYC
    google
    yes. it is an "A" to "A" usb extension cable. furthermore, it's male to female as well.
    Feb 2006
    USA
    thanks everyone!
    ~0okami.Digital
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    I am sure you can use CAT5 cable to make one.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    FLAC TheLlama's Avatar
    Jul 2004
    All over the world
    Quote Originally Posted by MatrixPC
    Perhaps. USB uses a different form of signaling than 802.X ethernet standards. USB employs something called differential signaling where there is actually a DATA+ and a DATA- line. I'm not sure about all the consequences (I'm a computer major, not an electronics), but there is a chance that the twisted pairs may have an adverse effect. If you want to try using ethernet cabling then I would recommend that you at least use STP and not UTP since USB cables must be shielded.
    Sep 2003
    Beach City, Socal
    Maybe I miss something, but I did see Fry's Electronic sell USB extension with CAT5 as cable.
    Maximum Bitrate v8 scimitar's Avatar
    Jan 2005
    Scotland
    hundreds of them are for sale on ebay with a 5m length
    http://search.ebay.com//search/searc...=usb+extension
    Feb 2006
    USA
    got it!
    5m USB 2.0 A/A ACTIVE EXTENSION CABLE.
    should be here by tuesday.
    ~0okami.Digital
  1. Best mountable, DC powered USB Hubs?
    By Dan Marsh in forum General Hardware Discussion
    Last Post: 05-19-2010, 03:34 PM
  2. Earthmate USB to Serial cable
    By New_Compact in forum GPS
    Last Post: 05-22-2008, 02:55 AM
  3. Audio crash after hibernate (USB alerts)
    By Peoples in forum RR Bug Tracker
    Last Post: 03-10-2005, 02:29 PM
  4. usb power problem: solved!
    By susman in forum General Hardware Discussion
    Last Post: 08-31-2004, 02:50 AM
  5. usb mouse stops working
    By corsamel in forum General Hardware Discussion
    Last Post: 10-18-2003, 06:53 AM
