Results 1 to 10 of 11
Thread: Which cases to fit an sp13000?
    Dec 2004
    I was just wondering what computer cases would fit the sp13000? I tried searching and only found someone selling an sp1300 and C134 case, but when I checked under the mp3car store it says "the M10000 motherboard is the only board that will fit in this case (c134)"
    Should the sp13000 be able to fit any case that accepts the other via mobos?
    Jul 2005
    Wales, UK
    The SP13000 is a standard mini ITX mobo (17mm x 17mm). It will fit in any case that supports the mini ITX boards from what I believe.
    LLOYDY
    Jan 2006
    Michigan
    Im going for this case for the sp1300
    Travla C134A-M1DC Black
    http://www.caseoutlet.com/shopexd.asp?id=369
    I was looking at another case from this place but its not listed as compatible with the motherboard (Travla C156 - Red/Black)
    Maximum Bitrate JimmyFitz's Avatar
    Nov 2005
    Austin, Texas
    I am using a Morex 3688 case. It works fine for the SP13000 as long as you don't need to use the PCI slot. It is also under $100. Some of the other Morex cases work well with that mobo too.
    ~Jimmy
    EL CAMINO's Avatar
    Jul 2005
    upland california us
    i'm building a system using the morex 3688 case,i replace the power supply with a m2-atx,same holes to mount it,another thing that i did is,installing a wireless pci card.it fits in it,i just cut the metal bracket make a hole on the case for the antenna.is a easy way and fast to build a very good carputer.all was done in less than 20 min.
    Springfield, IL
    i'm building my own out of plexiglass
    Dec 2004
    What about if I don't use low profile RAM? (Just using leftover 512 stick from desktop)
    StreetDeck Staff
    Jun 2006
    Columbia, MD.
    Quote Originally Posted by Dracord View Post
    We have updated the store. The SP13000 will fit into the C134 case. The case comes with a low profile heatsink that needs to be exchanged with the existing heatsink on the MB. No other MBS will fit inside this case due to the size of the heatsink and other hardware (ie PCMCIA and CF slot).
    If you are building a PC using the C134, you MUST use the low profile memory as the standard is too high for the hard drive and slot load cd/dvd bracket fit over. This case is small which means everything fits in very tightly.
    Sep 2006
    Fantastic, hehe this is my setup, the SP13000 fit wonderfully as long as u use ultra low profile memory, and boy its fun gettin all that pc in such a tiny case...
    I recommend ordering from logicsupply.com as they seemed to have the best prices on the case mobo and memory, i got my dvd rom and hd from newegg though.
    PM me if u have any questions.
    Dec 2004
    Well I just did some measuring, and the space I thought I was going to put it is too small, so now I have room to expand since i'm now using the glovebox. Rather then cramping the c134 and buying new low profile RAM, i think I'm going to get a bigger case.
    I now have a space of about 230 mm x x 280mm x 70mm to work with, so I'm thinking about the morex 3688, and seeing if can fit the opus 120 power supply in it which may be tricky because the 120 is a bit bigger then the M2-ATX.
    M2-ATX
    1.77"(W)x6.31"(L) x ~.75"
    Opus 120
    7.8" x 3.23" x 0.77"
    (200mm x 82mm x 20mm)
    I guess I'm on another problem here heh
  1. FS: Sturdy CarPC Cases
    By wi77iam in forum Classified Archive
    Last Post: 02-01-2006, 07:45 PM
  2. kit to fit dash?
    By Marshall_D in forum LCD/Display
    Last Post: 11-11-2005, 11:35 AM
  3. I fit an opus 90w in Morex case, Pix and a few tech Q's for safety
    By Tim97rs in forum General Hardware Discussion
    Last Post: 05-10-2005, 12:36 AM
  4. Pre Fabed Cases
    By Lando in forum General Hardware Discussion
    Last Post: 04-19-2004, 02:49 PM
  5. Trying to find a LCD to fit my Dash. Any help??
    By antimatter in forum LCD/Display
    Last Post: 02-07-2004, 01:29 PM
