Page 3 of 3 FirstFirst 123
Results 21 to 22 of 22
Thread: Continuous long beeps from mobo only on cold mornings...
  1. #21
    Jul 2004
    Quote Originally Posted by sama
    hey jackboot, try to run the supply in dumb-psu mode. see if that helps.
    Thanks for the response I've also tried the motherboard in dumb-psu mode with the same behaviour...I've also powered the M2-ATX's inputs with the 12V rail on a regular AC ATX PSU with the same behaviour so input voltage and current is ruled out too...
    I got an email from Ituner tech support today and they told me that the 3 beeps (post message) was a "keyboard card error" and to replace my keyboard. Yikes. That may be true if I was using an IBM BIOS from like 1980 when we actually used keyboard cards, but I am using an Intel BIOS (which I told them) and it is 2006.
    I think after reading some more that the problem may be a timing issue in the M2-ATX...
    Any other thoughts? Does the M2-ATX just suck?
  2. #22
    FLAC sama's Avatar
    Feb 2006
    London, UK
    my first m2 sucked. this one pumps (a lot of juice)
    did I mention I'm powering a 2.8GHz P4 chip with bluetooth, wifi, 2.5" h/d and a keyboard with no glitches?
    I've been more than happy with the replacement. so you may need a new one. it's just unfortunate that the first batch was poo!
  1. Embedding BSPlayer
    By Needstorage in forum Software & Software Development
    Last Post: 01-29-2007, 03:15 AM
  2. Programming Question in VB
    By az1324 in forum Software & Software Development
    Last Post: 10-01-2004, 09:24 PM
  3. Mobo Woes - Enlightenment needed
    By nzKAOSnz in forum Off Topic
    Last Post: 05-17-2004, 08:24 PM
  4. never lose focus
    By marsjell in forum Software & Software Development
    Last Post: 08-12-2002, 01:18 PM
  5. serial port shutdown signal
    By moahdib in forum Power Supplies
    Last Post: 08-03-2001, 08:52 PM
