Results 1 to 10 of 13
Thread: Solder in RCA to the Motherboard?
    Jan 2002
    I need your opinion before i try this.
    For those systems that have onboard sound,
    If you remove the "sound input block" (ie. unsolder the female connecter from the motherboard) could you solder on rca female plugs? This would eliminate the need for an rca soundcard and also reduce some noise that comes from the mini stereo conector.
    Any ideas?
    Jan 2002
    Venezuela
    sounds good to me.
    good idea.
    Sep 2001
    adapter.
    you could always just get an adapter from Radio Shack...
    the pinouts are very simple.
    I'm sure you could find out the correct connection info at www.technick.net if you wanna do it yourself.
    good luck,
    -Miles
    Near Completion: Intel P166 MMX, 32MB ram, 13GB Hard Drive, Keypad, 4x40 LCD. Sproggy MK2.6 ATX PSU. Win98SE with Winamp and Mark Zehnder Plugin. (Web-site: very soon)
    Jan 2002
    yes, but the point would be to elminate the ministereo connection
    Maximum Bitrate smashr2k's Avatar
    Jun 2000
    Virginia
    that seems like an awful amount of work just to get two rca plugs.... USB sound would be soo much easier, and would probably sound better in the long run.
    Car: 1999 Dark Green Mustang GT Coupe
    Audio: Alpine HU, JL 6ch Amp, JL Stealthbox and XR series components.
    Player: Empeg for now; something custom later.
    www.neotechpc.com - Custom built laptops!
    Jan 2002
    very true, i guess the question is if im to cheep to pop for the usb sound.
    FLAC MP3DUB's Avatar
    Jan 2002
    Chicagoland, IL
    so im guessing you dont drive the silver a6 in your icon?
    -Nick
    _____________________________
    www.mp3vw.com
    May 2001
    Thessaloniki, Greece
    What's the problem with a stereo 2.5mm pin to RCA pigtail and you want to get into this trouble? Messing your mobo with soldering iron sounds risky to me. Even for such a simple thing...
    Retired Admin Aaron Cake's Avatar
    Jan 2000
    London, Ontario, Canada
    If you are competant in soldering, then there is no reason not to do it. Most people don't realise this, but the mini phone jacks are terrible in cars. The contacts get all dirty, and the vibrations loosen them up after a few months.
    Apr 2001
    Here, There, Everywhere
    true, I desoldered the mini plugs off my Vibra 128. Just takes an hours time and a solder sucker tool.... then I just put a length of shielded fig 8 cable from the car to RCA jacks on the side of my case to goto my pre-amp/amp..
    Project - GAME OVER :(
