Results 1 to 2 of 2
Thread: MII12000 vs SP13000
    Constant Bitrate spaceskater's Avatar
    Feb 2005
    Boston,MA
    MII12000 vs SP13000
    I had the Via Epia MII12000 and now I have the new SP13000. I just wanted to point out the differences I have found until now. I have been using the SP13000 for about a month now. First the SP13000 is a bit faster, noticeably. It can handle many open programs a bit better than my old MII12000. The graphic accelerator is a bit more powerful, I do see the difference in 2D and 3D rendering in Google Earth for instance. The SATA drive does provide a faster HD connection. BUT, It takes longer to boot. I mean the post boot test takes about 5-8 seconds more than the MII12000. This is with the fastest possible settings I could configure in both systems. When it starts loading windows it is faster thought, the new 7200rpm sata drive makes a difference! Also the SP13000 does not work in low temperatures! I failed to start when I left my car outside for a long time. It was around 20 degrees and inside the car should be around 25-28. The computer refused to start before its temp was around 30. My MII12000 has worked many times with 15 degrees with no problems. That kind of disappointed me but I am lucky since I rarely leave my car outside for a long time.
    Well these are my findings until now. Anyone has anything to add, comment or ask?
    Will never be DONE! There is always something to add
    VIA EPIA SP13000,1GB DDR,80Gb 2.5” SATA HDD,8" Xenarc LCD with t/s,Linksys Bluetooth,Logitech wireless trackball,OBDII,RearView wide angle cam,XM radio,2 Wifi external antennas, Frodo,Navivoice
    Jun 2003
    Chicago
    my sp13000 works fine at temps below 30 degrees.
    the sp13000 is definetely an improvement over the m10000 but nothing to get excited about....
  1. epia sp13000 problems
    By shocker1185 in forum General Hardware Discussion
    Last Post: 02-16-2006, 12:37 PM
  2. Epia SP13000, Ampie case, M1-atx
    By skippy911 in forum Classified Archive
    Last Post: 01-28-2006, 10:48 PM
  3. Help me get 800x480 from EPIA SP13000
    By civic5zigen in forum LCD/Display
    Last Post: 10-27-2005, 04:24 PM
  4. More mobo comparisons.. SP13000 vs MII12000
    By replicant in forum General Hardware Discussion
    Last Post: 10-18-2005, 10:15 PM
  5. WTB: VIA EPIA MII12000 or VIA EPIA SP13000
    By kickercivic1 in forum Classified Archive
    Last Post: 08-28-2005, 12:29 PM
