Results 1 to 10 of 11
Thread: Head unit and pc
    Apr 2005
    Queens, New York
    Head unit and pc
    I have an after market headunit with Front/Rear/Sub/Aux inputs. I would like to have my head unit and my carpc both sound functional. I want to use my headunit for radio purposes and for cds. But I also want to use my CarPC for navi, mp3 and that stuff. How would i go about hooking that up? Also, is it possible to hook up my car pc to my head unit via AUX and control the volume?
    2002 Mitsubishi Galant
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    Souund Blaster Audigy2 NX
    OPUS ITX PC Case
    Low Bitrate shak's Avatar
    Jun 2004
    That is exactly how I have it. Connect your soundcard out to aux in.
    Apr 2005
    Queens, New York
    Quote Originally Posted by shak
    Do i hook up my amplifiers to my soundcard, then lineout on my sound card goes to AUX on my headunit?
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    OPUS ITX PC Case
    FLAC SnyperBob's Avatar
    Nov 2001
    Illinois
    Amplifiers? lol, you never mentioned anything about amplifiers. Connect the audio out on your carputer to your headunit's AUX input.
    Did you read the FAQ article before posting - or are you asking about a different setup, not mentioned in it?
    HOW TO: Get sound from PC to Car Stereo / Amp
    www.mobile-effects.com
    Free file hosting, picture gallery hosting for installs, PM me.
    Internet's first Front End Skin browser, featured installs, downloads, links, informative articles - all free to registered users.
    Apr 2005
    Queens, New York
    Quote Originally Posted by SnyperBob
    OK i have 2 amplifiers, 1 for my subs, 1 for my speakers. Rite now i have my amps connected straight to my Audigy 2 NX USB Front/Rear/Sub. I dont have my radio in yet. But when I put it in I want to have the ability to listen to the radio via HU and play cds via HU. SO to have my HU play through my amps as well what to I do? Do i have to connect my amps to both my headunit and my carpc soundcard? Baiscally put a spitter on each channel and run 1 cable to the carpc and the other to the HU for each channel?
    I want to listen to my carpc for mp3's and navigation through my amps. And my HU connect to my amps and listen to the radio and CDs. Is this possible?
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    OPUS ITX PC Case
    Mar 2006
    I would say run everything through your head unit and have it control the main volume.
    I'm not sure if it's possible the other way around.
    Bland...
    Apr 2005
    Queens, New York
    Quote Originally Posted by bland
    Bland...
    How would I run everything through my headunit? Then how would i get sound to my carpc?
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    OPUS ITX PC Case
    Apr 2005
    Queens, New York
    So nobody knows how?
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    OPUS ITX PC Case
    Apr 2005
    Queens, New York
    If i connect lineout on my pc sound card to AUX on my headunit, then from my amps to my FRONT/Rear/SUB on my Headunit, will the audio for my only work when the HU is on AUX rite>?
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    OPUS ITX PC Case
    May 2005
    put your amps to the proper outputs on the headunit
    put your computer to the aux input on the headunit
    then, you can just switch between aux in, radio, or cd player via the headunit. The headunits volume control will also be the main volume for everything. I have my Carpc set to max, and just lower it at the headunit.
    Take 2 - '03 Audi A4
    macmini with an 8" widescreen (in progress)
    My 2004 Ford Ranger:
    14" LCD w/ custom made aluminum bezel
    Completly custom computer case
    status: Totaled
  1. Replies: 15
    Last Post: 02-14-2006, 11:50 PM
  2. The ultimate head unit and PC
    By maxjet in forum General Hardware Discussion
    Last Post: 01-06-2006, 03:33 PM
  3. Head unit and Car PC
    By hussein_787 in forum Newbie
    Last Post: 08-13-2004, 06:23 PM
  4. using head unit to control/display from pc...
    By vincerules in forum General Hardware Discussion
    Last Post: 01-23-2003, 05:18 AM
  5. Easy head unit question, and PC to amp question.
    By dudah85 in forum General Hardware Discussion
    Last Post: 09-09-2001, 03:57 PM
