Results 1 to 7 of 7
Thread: Slimline eject button relocation
    Feb 2006
    Westfield, MA
    Has anyone had any success relocating a slimline slot-load dvd drive eject button? I have not purchased one yet, I am assuming the button is soldered to 2 contacts on the board. My plan is to solder 2 wires to these contacts and add an external switch. The load opening in the dash will be just slightly larger than a dvd, so the built in switch is covered.
    Aug 2002
    Eau Claire, Wi
    i have a slot loading drive out of an old imac. I soldered wires and a momentary push button for an eject button and it workd fine. On my drive the contacts are very small, so take your time when soldering and make sure you have a small tip for your iron. I used wire from an old 80 wire IDE cable. This wire works great for small things since the 80 wire IDEs are a very fine guage solid wire, not stranded.
    System: AMD Duron 1200+ , 512 MB ram , usb sb mp3+ , Tview 7" touchscreen , M1-ATX PSU , Slot Load iMac DVD-Rom , 40 GB laptop HDD, netgear USB 802.11g
    Progress: Installation: 90% Dash fabrication: 80%
    Parts Needed: USB GPS
    Feb 2006
    Westfield, MA
    Thanks for the tip, how does the imac dvd-rom interface with your pc, is it just a standard slim-line connector?
    Aug 2002
    Eau Claire, Wi
    yes, the connector is a standard slimline connector, but I believe it is rotated 180 degrees from what most drives have. The one i have was pulled straight from an imac and still had the adapter to standard ide attached. Other adatpers should work, but they may stick out to the side a bit. For a while the imac drives were the only slimline slot loading drives you could get. There are lots of threads about them.
    Feb 2005
    West Valley City, Utah
    couldnt you just stick a button through the dash? or eject it from my computer?
    Progress,.... that is what I keep forgetting ;)
    planning_[++++++++++]. 110%
    parts___[++++++----] around 60%
    install___[-----------] -9,000%
    Variable Bitrate kamikaze2112's Avatar
    Feb 2005
    Barrie Ontario
    you could.....but where's the fun in that?
    Feb 2005
    sorry. I didnt mean to make too much sense there.
  1. DVD Button Relocation?
    By toxsickcity in forum FrodoPlayer
    Last Post: 10-16-2005, 06:15 PM
  2. Add a EJECT button with NCS !
    By netsuo in forum NeoCar Media Center
    Last Post: 06-08-2005, 09:20 AM
  3. Face Plate Relocation EJECT Problem SOLVED!!!
    By guyofscience in forum Car Audio
    Last Post: 04-08-2005, 11:50 AM
  4. Eject Button?
    By C1500 in forum NeoCar Media Center
    Last Post: 11-22-2004, 12:40 PM
  5. Lilliput button relocation
    By greddy0 in forum LCD/Display
    Last Post: 12-17-2003, 06:00 PM
