Results 1 to 7 of 7
Thread: Via M1000
    Variable Bitrate UM_Fan's Avatar
    Feb 2005
    Miami, Florida. 305
    Via M10000 Memory
    Quick question before I shot myself....
    M10000 uses DDR266, could I use PC3200
    Crazy Miami Drivers
    R.I.P. My first ever NEW Car
    Old installation
    New Install!!!
    |-------------------100%|Cables ran
    |----------------85%----|Software RR
    |--------------80%------|Complete
    [/SIZE]
    Sep 2005
    Yes, just don't use ECC Registered ram. I'd only use such nice ram if you already have it. The m10k won't be able to take advantage of it.
    Feb 2005
    Miami, Florida. 305
    Thanks...I'm having POST problems...
    Crazy Miami Drivers
    Old installation
    New Install!!!
    [/SIZE]
    Feb 2005
    Miami, Florida. 305
    This is really driving me
    Here's what I got: Kingston
    Search Results for: KVR400X64C3A/512
    Description: 512MB 400MHz DDR Non-ECC CL3 (3-3-3) DIMM
    Detailed Specifications: Standard 64M X 64 Non-ECC 400MHz 184-pin Unbuffered DIMM (SDRAM-DDR, 2.6V, CL3, Gold)
    When I boot up I get 1 long beep and it repeats..If I reset the bios on the MoBo I can get into the Bios.
    Once I do any changes and reboot noting but BEEEP
    I created a bootable disk (CD) and downloaded on Via website there flash utility AWFL823B.EXE and the BIOS file.
    Keep in mind that the only way for me to do anything, I have to reset the bios and unplug the the power and wait a few minutes otherwise I can't do anything and all I hear is that one long beep.
    I boot up and got DOS type the cmd.: AWFL823B BIOS.BIN
    And nothing...
    As if there's nothing on the CD. Take the cd out, pop in my PC...it there!!! WTF am I doing wrong????
    FYI: The MoBo is used and purchased from a user here....
    Crazy Miami Drivers
    Old installation
    New Install!!!
    [/SIZE]
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    I would just go buy a stick of RAM with the right speed. Putting RAM in with a faster rating will actually slow down other parts of the system, espically he CPU because it can't keep up with the memory. 512 266 is perfect for that board
    Feb 2005
    Miami, Florida. 305
    Went to Tiger Direct Outstore...and pickup some memory.
    Got it to work
    I was about ready take out the baseball bat....
    Crazy Miami Drivers
    Old installation
    New Install!!!
    [/SIZE]
    Variable Bitrate Splash-X's Avatar
    Mar 2006
    Palm Harbor, FL
    I know this is a little late, but it is still relivant.
    Just some notes about your memory. The beep means the memory is not registering properly. If you flashed the BIOS and you were able to boot with that memory then the memory IS compatible. It sounds like the VIA has some settings in the bios for auto detecting the memory speed or something similar. I don't have the board you are commenting about yet otherwise I would go in and check the bios for the settings you should need.
    You could try using the Fail Safe settings. If it works then, simply play with the memory multiplier or underclock the memory.
  1. AUDIO AND VIDEO seperation on the m1000
    By MaleBuffy in forum General Hardware Discussion
    Last Post: 01-09-2006, 12:46 PM
  2. Via Epia M1000 - RAM question
    By blk02si in forum General Hardware Discussion
    Last Post: 12-28-2005, 05:41 PM
  3. Microphones on VIA M1000
    By daveg360 in forum Input Devices
    Last Post: 12-21-2005, 10:28 AM
  4. 800 - M1000 upgrade ( power??)
    By Jamez_Warner in forum Power Supplies
    Last Post: 01-26-2004, 03:09 PM
  5. Beware of look alikes- EPIA M1000
    By gizmomkr in forum General Hardware Discussion
    Last Post: 10-31-2003, 06:32 AM
