wow....that sucks......if i were you i'd trade me for my used lilliput...i dont have those issues.....but the left side of the touchscreen stopped responding
I'm just getting aquainted my new Gain 700TSV from Armen...
I'm running into two issues:
1. When I send 800x480 to it I get the message "not available." Just before the message the OSD reads 640x480. Then I see the upper half of the screen for a slight moment before it blacks out with the "not available" message.
2. When I first go into 800x600 (after power up) I get a flickering slightly fuzzy image. After I change the scaler feature (4:3 then back to 16:9) or select "default yes/+" in the menu it goes away.
Anybody else run into these issues?
PC Components:
My work log
Got some land to sell me too I bet!Originally Posted by Peoples
Have not had those issues... I got the not available screen when I tried 1600x1200, but not 800x600.
Do both problems happen on other computers too?
Hey Dash,
I bought one from Armen in early February but did not get to it right away. When I set it up last week, I noticed one pixel was stuck on (Green all the time). I returned mine for a replacement. It should arrive tomorrow. Anyway, Armen took care of everything very quickly and he has excelent customer service. Just thought people should know since all eanyone ever hears about is the negative.
Unfortunately my Aopen Pandora does not do 800x480 so I intend to run it at 640x480.
Best regards,
Marc
have you tired different refresh rates? i have issued with my old ATI graphics on my laptop but thats cos it is an old card and cant do dual outout properly for the gain. if i switch to only the gain in 800x600 or 1024x768 it is fine though.
How come i didn't get an AC adapter with this =(
Did everyone except me get an ac adapter with their screen?
04 Acura TL w/ core2duo 2ghz laptop w/ 1gb RAM on a docking station.
Fast car, fast PC. ;)
http://www.arcdesigns.net/carpc/
My TL CarPC ver2
FSR Flash Skin w/ moving weather maps
I had some issues with the default resfresh rate, I set it to 75HZ manually and that solved the problems.
Asus MicroATX with GeFore 6100, Mobile Sempron 3300+, 1Gig Ram, 320GB 3.5" 7200UPM HDD, M2-ATX, Gain/Xenarc 7"
Fast IS my copilot
To bad the issue has notting to do with Gain 700TSV. I never have or had any problem. Its your configuration on the pc.
I didn't either. My testing has been restricted to the garage with the cig adapter. Sucks big time.Originally Posted by moahdib
