Results 1 to 3 of 3
Thread: sp13000 front panel pin numbering... im confused. help :(
    Variable Bitrate 0okami's Avatar
    Feb 2006
    USA
    Well, it seems i forgot to take note when attaching my front panel wires and i pulled them all off to re-accomodate things around...
    I forgot where the power from the Opus goes...
    Im reading the manual of the sp13000 and it mentions:
    Power button pin 6... and it gives me pin 1 location.. but im not sure how to count the pins... does it go:
    8-9-10-11........
    1234567
    or is it:
    2468......
    1357.......
    as it is now, my opus keeps going into code 2 (wiring issue most likely)
    im so lost right now. Reading the document: EPIA-SP_v100.pdf (page 26)
    available from: http://www.via.com.tw/download/mainb...IA-SP_v100.pdf
    Curses! I should have taken note how i had that wire before unpluging it!
    ~0okami.Digital
    Feb 2006
    USA
    ah! looks like i did in fact take a picture... *all fixed now*
    *attaches it for the sake of others*
    back row you see red and white, then green and white.... the green and white in tbe back is the opus power switch. keep polarity in mind.
    ~0okami.Digital
    Newbie pdogg's Avatar
    Jan 2006
    Las Vegas
    Power wire
    I have built alot of computers in the past and never had to attach the pins across. Its usually up and down. Also the issue with the opus is that you could have the power button pins backwards.
  1. BMW E46 Owners with DSP systems and no HU
    By edrock200 in forum Newbie
    Last Post: 12-16-2006, 12:21 PM
  2. Confused .....wich front end !!
    By Boyracer in forum Road Runner
    Last Post: 03-01-2005, 04:22 PM
  3. Front Panel thing
    By killerferret666 in forum General Hardware Discussion
    Last Post: 02-17-2005, 01:57 PM
  4. Front Panel LCDs/VFDs?
    By integsrtite in forum LCD/Display
    Last Post: 06-05-2004, 05:03 AM
  5. using cat5 to wire front panel
    By Crast in forum General Hardware Discussion
    Last Post: 12-04-2001, 02:30 PM
