LCD Controller and DVD Decoder
Ok I've done some searching and let's see if I have come to the correct conclusion. I will be using a p200MMX, and I wanted to use a ATI card for decoding DVD and as a TV Tuner. I will be using a LCD that has and External controller card. Becuase I'm using this type of LCD setup, does it mean that I have no way of feeding the video signal from the ATI into the LCD controller. I also plan on buying 2 5" LCD for the back seats, maybe the PSONE. Would I just be better off buying an addtional one for the front as well, eliminating the LCD/external controller combo, and then using the ATI composite out (split 3 ways) to feed the LCD's? If I do go this route, what type of quality can I expect compared to using the laptop LCD?
Also as another option, I may have access to a PII450. So If I use this and use the LCD/controller combo, use software decoding for DVD, and use a dedicated TV Tuner, will I be able to view DVD and TV on my LCD. I could then feed a TV signal into the 2 addtional 5" LCD's, but how do I get DVD to those units?
