Results 1 to 9 of 9
Thread: Full sized DVD in HP E-PC?
    Nov 2005
    I have most of an hp e-pc (working on a power supply now).
    It uses a regular Teac Notebook CD Drive. Is there any kind of adapter I can buy to let me use a full size (5.25") DVD drive on it. The cable for the HDD is a normal IDE, but the cable for the notebook cd is much smaller. Any advice? Thanks.
    Mar 2006
    San Diego, CA
    If you have a regular IDE connector for the HDD, can't you just put the 5.25" DVD drive on that IDE channel? Or do you have two IDE devices already on that channel?
    Variable Bitrate billmee's Avatar
    May 2005
    USA
    you could use a slimline dvd sold in the mp3car store
    whatcha gonna do for power?
    I'm currently using an inverter with my E-PC, but would like to go dc-dc for a less power hungry system
    Nov 2005
    Quote Originally Posted by Puffanug
    DOH! I did not think of that! I only have one IDE drive. I guess there is no reason I can not just swap cables and use it that way. Thanks!
    Nov 2005
    Quote Originally Posted by billmee
    Well there are two E-PCs that I know of with external power supplies. One just uses a regular 12v to 19v notebook adapter in the car. The other needs both 12v and 19v fed in to it.
    May 2005
    USA
    Quote Originally Posted by shrug
    Yeah I've got the latter. I was thinking of making my own psu using a 19v and a 12v supply then using a time delay relay to provide the power ok signal.
    I'm just not sure if the power savings will be worth the effort.
    My only goal is to increase my run time on my second battery.
    Nov 2005
    See I was wondering if that PGOOD wire was even needed. If so, I have no idea how to hook that up.
    May 2005
    USA
    POWER GOOD and GOOD FOR YOU
    Ok, my setup has the E-PC PSU feeding the PC via a cheap terminal strip.
    I did this to figure out how much current each of the supplies was providing.
    I made these measurements this morning, and also looked at the power good signal.
    I found the following, peak load conditions;
    19v supply 1.3 Amps
    12v supply 4.2 Amps
    Power Good 3.3volts immediately when swithcing on the PSU.
    It appears to be generated by the PC not the PSU.
    And now for the good news
    THE PC RUNS WITH IT DISCONNECTED, IT CAN BE IGNORED
    May 2005
    USA
    E-PC psu pictures
    Fyi
  1. laptop DVD drive for car pc?
    By passatb5 in forum General Hardware Discussion
    Last Post: 07-27-2005, 07:40 PM
  2. Help with HP ipaq H6315 pocket pc 2003
    By fcanozo in forum PhoneControl
    Last Post: 02-13-2005, 01:21 PM
  3. View DVD & PC with VGA (640 x 480)???
    By mndk101 in forum LCD/Display
    Last Post: 07-09-2003, 10:57 PM
  4. PC CD/ DVD skipping problems?
    By Euclid in forum General Hardware Discussion
    Last Post: 02-05-2003, 09:43 PM
  5. Million $ Questiosn: HD screw size and wahz a good PC DVD player?
    By Tony S in forum General Hardware Discussion
    Last Post: 05-05-2001, 02:31 PM
