Results 1 to 3 of 3
Thread: USB device monitor
    Nov 2005
    Missouri
    USB device monitor
    There was a recent discussion (which I can't find now) about the effect of plugging a USB 1.0 device into a 2.0 hub. Basically the question was whether or not doing so slowed all the devices to 1.0 speed.
    Is there any software that allows you to monitor a USB port/device? Just something simple (read free) that will let you know what speed it is operating at?
    Thanks...Paul
    Nov 2005
    Missouri
    So was it a dumb question, or does no-one know?
    FLAC sama's Avatar
    Feb 2006
    London, UK
    usually if you plug a usb 2 device into a usb 1 port, it will tell you that you've done that.
    sticking a usb 1 onto a usb 2 should not slow down the rest of the devices. the way I understand it is that a device checks to see if the bus is busy and will try to post something down the bus when it's quite. if it gets a reponse then it carries on (again, checking the bus each time it sends a packet). the speed that this happens is so fast that eventually everything gets communicated.
    having more devices on there may slow thigns a little however. not to a great degre usually, it depends what you're doing with the bus. If 128 hard drives are all trying to transmit down that bus, then there would be collisions left right and center.
  1. Installing a USB Hub up-front? Read this...
    By hd54321 in forum General Hardware Discussion
    Last Post: 02-09-2007, 12:49 PM
  2. Replies: 15
    Last Post: 05-04-2006, 05:53 PM
  3. lilliput usb device not recognized!!!!
    By lax4321 in forum LCD/Display
    Last Post: 08-10-2005, 09:57 AM
  4. Replies: 1
    Last Post: 04-10-2005, 06:24 PM
  5. Replies: 1
    Last Post: 03-23-2005, 12:41 PM
