Results 1 to 8 of 8
Thread: Sound Blaster AUdigy 2 NX Problem
    Apr 2005
    Queens, New York
    Hey guys whats up, I was just wondering if any you guys are experiencing the same problem I am. with my NX when I am playing music it seems to skip or make a little noise every so often. It skips for like a half a second and does it a couple times and then stops. IS there any way to fix this? I updated the software and iit still didnt fix it.....
    2002 Mitsubishi Galant
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    Souund Blaster Audigy2 NX
    OPUS ITX PC Case
    Constant Bitrate Phythorian's Avatar
    Dec 2004
    Netherlands
    I had a problem like that, had it solved by powering the NX with his own PSU.
    There just wasn't enough in my opus120 to power this aswell.
    After that I never heard a single noise again.
    To find out, just power the NX at home with his original psu, instead of the one in your car.
    Finished!
    pc 99% - install 100% - audio 100%
    Apr 2005
    Queens, New York
    Ahhh, I see I have it powered with my opus120, what did you power it with? A POL 15w?
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    OPUS ITX PC Case
    Dec 2004
    Netherlands
    I used an ITPS from my previous install, and a friend of mine made some psu for that. I'll guess any regulated psu from about 15W will do.
    Finished!
    FLAC chut's Avatar
    Jul 2003
    San Antonio, TX. USA
    Hey, got a question for you folks....are you satisfied with the volume from your audigy's? Im thinking about buying one and want to know if it gets loud enough for a convertible? I've got a 1200 watt amp after the soundcard and the sound from my epia is plenty loud, but I want the optical input from the audigy.
    What do y'all think?
    Stop Buying New Music CD's.
    Hit The RIAA where it lives.
    Indash Motorized 7", Epia Nehimiah, 512 MB, 80 GB, DVD, Wireless G, XP Pro, XM PCR, Kenwwod 5 Channel 1200 Watt Amp.
    May 2006
    I have a problem with my audigy 2 nx i dont get any sound whatsoever from the Center/subwoofer line out do you think ive got a dodgy card?
    Variable Bitrate Redian's Avatar
    Apr 2006
    Connecticut, USA
    red, test it outside of your car as well, as well as the wires you are using... and even the sub you are using, no point in getting a new card if that one works
    2004 Impreza WRX CarPC Install
    I am willing to host any legal downloads that may benefit the CarPC community - PM for info
    "When you go 0-60 in 4.5 seconds, you don't need a made up character called fast. Thats what makes a Subaru, a Subaru."
    DG4L
    Mar 2006
    Detroit MI. Westside(M-39 EXIT 9)
    I've had almost every (creative) problem you can think of and in almost every case DRIVER UPDATE! is the answer! Register to get the best driver updates.
    CREATIVE RULEZ !!!!!!
    Oh yea! as for Centre and Sub output's it take's time but you will get them to work, if you play a 5.1 movie they will work,but if you want them to work for mp3's you have to use simulated setting's to get all channels on. if it's not working from there re-install drivers cause you might screwed up something trying to fix it.
    Underconstruction for 2007 !!!!
  1. sound from front channel only on audigy 2 nx
    By Carter in forum General Hardware Discussion
    Last Post: 09-26-2005, 06:23 AM
  2. Audigy 2 NX and subwoofer, whats the deal?
    By jedi7001 in forum General Hardware Discussion
    Last Post: 05-15-2005, 02:17 AM
  3. USB Sound blaster vs Audigy NX 2 USB
    By sivart321 in forum General Hardware Discussion
    Last Post: 04-07-2005, 05:06 PM
  4. Fs:sound Blaster Audigy 2 Nx Usb2.0 External
    By muldrick in forum Classified Archive
    Last Post: 01-21-2005, 10:13 PM
  5. Strange Audigy 2 NX problem
    By techy101 in forum General Hardware Discussion
    Last Post: 01-12-2005, 06:18 PM
