Page 1 of 4 1234 LastLast
Results 1 to 10 of 34
Thread: HDD vibration solution
    Aug 2005
    I`ve spent the last 2 hrs searching the forums. A while ago there was a post with a blue 3.5" external HDD enclosure with silicon damping built in. Anyone help me out finding it again. The reasonI am asking is I have designed a Carputer with surveilance built in (upto 16 channels of realtime h264 video encoding) designed for a toushscreen interface and would like to have a 3.5" storage soltuion as opposed to a 2.5" storage solution.
    Fusion Brain Creator
    Mar 2005
    oh man
    NO ONE
    I repeat
    NO ONE
    has ever had a HDD fail from vibration in a car
    people have gotten into major car accidents with teh carputer on and the HDD is fine
    Aug 2005
    Yeah but my application is really for the transport industry (buses and coaches) and I have seen lots of drives fail in that environment (my last job was with one of the UK`s largest installers of in vehicle CCTV)
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Ahhhh BS.
    As a user of an in Car 3.5 HD for 9 years and several car crashes with the HD in use.
    TruckinMP3
    Read the FAQ!
    Mar 2006
    Don't listen to these guys
    You're putting a commercial product out. You need to at the minimum put on a good show (no matter one's opinion on whether a certain environment variable affects longevity)
    http://froogle.google.com/froogle?hl...ch&sa=N&tab=wf
    Hope that helps some. I never saw the post you are looking for.
    Nov 2005
    The short version:
    Modern HDDs (especially 2.5") are engineering to withstand tolerances beyond the human body. The HDD would survive conditions that would kill you.
    The long version:
    <you have to ask somebody else..>
    My opinion:
    Is the cost of damping in every install lower than the cost of replacing failed drives (assuming you can estimate the failure rate)? Alternatively would it be cheaper to built redundancy (RAID?) into the system?
    Let the flames begin..
    Variable Bitrate quantum's Avatar
    Sep 2005
    Quote Originally Posted by TruckinMP3
    Ahhhh BS.
    Hmmm, car PC = several car crashes... I'd better call my insurance company and raise my policy limits before I start my install!
    Low Bitrate PCModifiers's Avatar
    Dec 2005
    I hope all these car crashes you guys are having aren't due to having a computer in your car
    No one ever said this stuff was easy...The Mobile Desktop
    Progress[**********]
    Dolby Digital Real-time Encoding*Desktop Computer*Athlon XP Mobile*ASUS A7N8X Deluxe*Kingston Hyper X*5.25" CDRW and DVD drives*Lilliput 8" LCD*Mag 14" LCD
    Given that the 2.5" drives are supposed to be more shock resistant, they sure fail often enough. I have one laptop that is on it's 3rd drive. My car PC is still going strong with it's 3.5" drive over the same time period.
    I mounted it to the top of the case using rubber grommits in the mounting holes to give it some vibration isolation. Mostly I did it for the noise reduction though.
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    my 3.5" is solidly mounted horizontally in my car with sport suspension and rubber bands for tires. not a problem yet.
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
  1. Hard drive shock / vibration thoughts
    By S11D336B in forum General Hardware Discussion
    Last Post: 09-27-2006, 12:40 AM
  2. a serious solution
    By sohaibma in forum Power Supplies
    Last Post: 04-06-2005, 03:44 PM
  3. HDD gone bad?
    By VanMan69 in forum General Hardware Discussion
    Last Post: 08-07-2004, 06:55 AM
  4. Standard HDD to FDD power adaptor?!
    By coachreed in forum Power Supplies
    Last Post: 06-10-2004, 06:11 AM
  5. Possible Vibration solution...
    By codelogic in forum General Hardware Discussion
    Last Post: 04-08-2004, 03:46 PM
