Results 1 to 2 of 2
Thread: Searching for carpet mount device?
    Variable Bitrate DaveB's Avatar
    Mar 2004
    I need to mount my XM radio box under the passenger seat. I'm guessing its about 4 or 5 inches square. It won't take much to hold it. Has anyone ever seen anything where you would have a couple of long pins that would push into and under the carpet and pad, with perhaps a flat plate on the other end where I could stick some 2-sided tape? I think I have seen something along those lines which is used to hold floor mats in place.
    I know I could make something but if there is already a solution that I could pick up at Pep Boyz, or some local place, I'd prefer not to reinvent the wheel.
    Ideas?
    8" Lilli TS
    MB896F Mini-ITX MB
    2GHZ Dothan 533MHz FSB CPU
    1GB SDRAM DDR2 533
    Seagate 300GB SATA150 HD
    ENGENIUS WiFi MINI-PCI CARD 802.11A B 400MW OUT
    Pioneer Slot Load SLIM DVDRW
    Bluetooth V2 USB 2 Dongle
    3COM BKP Cam
    Jan 2006
    Arkansas
    Well depending on what type of carpet you have, you could use some extra-strength velcro, just the scratchy side, and put a stripe or two of it down the bottom of the box...
    Other than that, another thing you could probably use is headliner tacks. They are screw styled tacks that are used to hold the ceiling up on a car when it sags (on older cars). You can "screw" that into the carpet, and it should hold fine.
    I'd suggest the velcro solution first.
    Jim
    2012 Honda Pilot (In Progress)
    2010 Honda Accord (After the Pilot)
    2008 Honda VTX1800N
  1. Replies: 1
    Last Post: 03-14-2005, 12:45 PM
  2. Where to mount screen in here?
    By PCGUY112887 in forum General Hardware Discussion
    Last Post: 03-13-2005, 11:24 PM
  3. Semi-permanent Screen Mount
    By ukchris in forum Fabrication
    Last Post: 03-11-2005, 03:27 PM
  4. Flex-arm mount , good for LCD or keyboard
    By gizmomkr in forum Classified Archive
    Last Post: 02-19-2001, 03:17 PM
  5. prpoer way to mount hardrive
    By asif in forum General Hardware Discussion
    Last Post: 07-11-2000, 10:12 AM
