Results 1 to 7 of 7
Thread: Temperature sensor
    Variable Bitrate checksum's Avatar
    Feb 2006
    Columbia/MD
    Temperature sensor
    Anybody know of a good temp sensor I can use wuth my carpc, something that would connect to the com port of the PC and give me the outside temperature?
    2005 Nissan Altima - Completed 2007
    2010 Nissan Altima - Coming Soon...
    Feb 2006
    Columbia/MD
    Well, after doing some searching I found this:
    http://store.qkits.com/moreinfo.cfm/QK145
    If I am not mistaken, this will work with road runner, it plugs into the serial port, then you solder a sensor on one of the channels. right?
    This one:
    http://store.qkits.com/moreinfo.cfm/DS18S20
    Now my question is, if I need to place the sensor outside the car, what is the best placement for the sensor, since I am trying to read outiside temperature. And since the sensor is so small, I am guessing it might break off easily.
    Also is there a way to switch between the channels in case you want to use another sensor, let's say inside the car?
    Low Bitrate agentloveless's Avatar
    Aug 2005
    So Cal
    4 Sensors Temperature Measurement Kit (Optional for Road Runner):
    http://www.kitsrus.com/kits.html#k145
    (Check Main site www.kitsrus.com for ordering information)
    Placement of the sensor is up to you, mine is attached to the inside of the trunk on the metal, seems to work well for me and be fairly accurate.
    Feb 2006
    Columbia/MD
    Thanks, that's the same one I have posted, my question is if you have more than one sensor, how do you switch between them?? Since this supports up to 4 channels...
    But are you reading the outside temp since it is placed inside of the trunk?? Also did you just taped it there or did you use some kind of glue??
    Aug 2005
    So Cal
    I wish I new the name of the stuff I used. It was some heatsink compound for my pc I had lying around. I know it seems funny that my outside sensor is inside but I figured if it didn't give accurate readings i could simply disconect the sensor and put on somewhere else. Also, maybe this method would not work so well for the darker collored cars.
    Anyways, I only have two channels hooked up, and in road runner it displays the inside and outside at the same time so I do not need to switch between them. Hope that is helpful.
    Feb 2006
    Columbia/MD
    Thanks,
    Actually these kits are fairly easy to build. I can easily build one at my work, we have all the tools necessary, just have to look around the lab and find all the right parts. THe only problem would be programming the pic.
    Nov 2005
    Missouri
    Most OEM temp sensors are mounted either under the front bumper or attached to a side mirror.
  1. Relocating Portable DVD Remote Sensor...
    By AEFL92 in forum General Hardware Discussion
    Last Post: 09-10-2007, 03:03 PM
  2. RR Temperature Sensor - Ready out of box?
    By thestoogeo in forum Road Runner
    Last Post: 10-15-2005, 10:59 AM
  3. Offset for phidgets / temperature sensor
    By skippy76 in forum Road Runner
    Last Post: 10-10-2005, 05:04 PM
  4. Ideal location for a temperature sensor??
    By carpcnoobie in forum General Hardware Discussion
    Last Post: 10-07-2005, 12:07 AM
  5. Phidget Temperature sensor calibration
    Last Post: 10-05-2005, 10:47 PM
