Results 1 to 10 of 13
Thread: Pin Mod Done!!! One Last Question Tho!!
    Constant Bitrate ironic's Avatar
    Aug 2005
    Gibraltar(UK)
    Exclamation Pin Mod Done!!! One Last Question Tho!!
    Hi
    Ive just done the pin mod, everything runs nice.
    However, temperature has risen from 48 to 60.
    And vcore is still the same...
    CPU specs of my pc say that it shud run at 1.4v
    Shud i do the pin mod to change it to 1.475v??
    DarqueP??? HELP??
    MSI KM4M-V Mobo -- AMD Athlon XP-M 1900+ -- 512MB DDR RAM -- LinITX 7" Touchscreen -- Seagate 8.4GB HDD -- LG DVDRW -- Onboard Graphics Card -- Onboard 5.1 surround sound -- Bluetooth Dongle -- RoyalTek Saphire GPS -- M2-ATX psu
    Elsewhere
    There's no need to start new threads, man. Continuing the other thread is just fine.
    When you say 60, I'm assuming it's celsius. You can try dropping the vCore to 1.475v. That's what I did with mine, althought the specs for the CPU specify 1.4v, I believe.
    My CPU typically runs about 100-105 F and I have no issues whatsoever.
    How about the Wiki?
    Aug 2005
    Gibraltar(UK)
    Unhappy ive done the vcore pin mod but...
    sorry DP
    i'll carry on using this thread from now on.
    ok.i decided to do the vcore pin mod, but IT DIDNT CHANGE IT!!!
    im checking the PC HEALTH section and it says:
    CPU TEMP: 61C/141F
    Vcore: fluctuates between 1.68 and 1.71 volts
    HEEEEEEEEEEELP!!!
    Elsewhere
    I couldn't tell you what's going on, then. I set the vCore on my setup witht eh pin mod and I've tested it and it's correct. Are you sure you put the wire in the right holes for the 1.475v?
    Also, is there anything in the BIOS that sets the vCore? That may need to be set to automatically detect or something.
    How about the Wiki?
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Quote Originally Posted by DarquePervert
    Which CPU you are running?
    Mine(2500XPM) is running around 38C-50C. I don't know what it is in F... probably over 100.
    I try to bring it down a little, but didn't have time or hot enuff to do it yet.
    is it where the "jumper" for vCore mod?
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Aug 2005
    Gibraltar(UK)
    Exclamation
    Nope.
    No chance whatsoever to change vcore.
    I will check again but, i doubt i did the wrong pin mod.
    If i made the correct pin mod, what else can i do?
    Will the cpu run ok at those temps and voltages?
    what happens if i increase the FSB to 166 or 200 and decrease the multiplier but still achieving 1600mhz?
    will that run it cooler?
    im lost man
    Aug 2005
    Gibraltar(UK)
    Exclamation
    Quote Originally Posted by MatrixPC
    My cpu is an XP-M 1900+ (1600mhz) - (AXMD1900FQV3C/133mhz/12x clock multi/1.4vcore/thoroghbred).
    any help?
    thanks!
    Aug 2005
    Gibraltar(UK)
    Exclamation
    Yes! its exaclty on that place that i did the vcore pin mod, but nothing changed.
    any ideas?
    thanks.
    Sep 2003
    Beach City, Socal
    I thought ALL AMD-VIA chipset mobo has jumper selection for multiplier.
    Weird. The SOYO mobo I have (K7MVE) did run the XP-M fine without any pin mod and temp never hotter than 38C crunching Prime95 for days. That is when I did the test on the CPU, but I am not using that mobo in the car setup.
    Aug 2005
    Gibraltar(UK)
    well, if it has one, it aint in the manual!!!
    what can i do now guys?
  1. BMW E46 Owners with DSP systems and no HU
    By edrock200 in forum Newbie
    Last Post: 05-24-2012, 11:59 PM
  2. XM on Carputer THE GUIDE
    By Prindle19 in forum Hardware Development
    Last Post: 10-25-2007, 06:02 AM
  3. 2.5" IDE cable question...
    By SamDude in forum General Hardware Discussion
    Last Post: 01-13-2006, 05:49 PM
  4. Question about Switchs and Wiring
    By PapaPrem in forum General Hardware Discussion
    Last Post: 02-12-2005, 02:42 AM
  5. Calling the Forward Converters Gurus - Please Help !!
    By Zznakie in forum Power Supplies
    Last Post: 10-20-2004, 02:11 PM
