Results 1 to 10 of 10
Thread: Software to test hardware ?
    Maximum Bitrate SAScooby's Avatar
    Feb 2004
    Johannesburg, South Africa
    Hi
    I am looking for some software that can run detailed tests on hardware, I had one years ago that would copy data from hdd to ram and test for errors and speed and also put the processor to work at certain thresholds / loads to check for errors etc, but I dont have this anymore.
    I have certain unexplainable resets on my pc and think its psu but it could be ram / processor / overheating of components.
    If you have a link for something along these lines please let me know
    Nano ITX / 512 MB / 60 GB / Panasonic slot load / M1-ATX / Bu303 / Sound blaster 24 / PPi amps / rockford sub
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    Eh, there's really no substitute for experience and knowledge, but look for an ISO image of Hiren's boot cd. This has all kinds of tools in it to test hardware with. As far as overheating goes, is anything too hot to touch? If so, you got heat problems.
    But, Hiren's boot cd is awesome, and there are torrents for it all over. I think the current version right now is 7.9 Here's a link to what it contains. http://homepage.ntlworld.com/hiren.thanki/bootcd.html
    Tidder
    Try RevFE
    Sep 2003
    New Mexico, USA
    Also, there's a program to check if your processor is running stable under heavy load. http://users.bigpond.net.au/cpuburn/ - Note, this is a windows prog
    To watch the temp, you can use this prog http://www.almico.com/speedfan.php
    It has to support your chipset/motherboard, but it's list is getting bigger every day.
    I've used both of these progs to burn in gaming systems I've built. Work great for me.
    Tidder
    Try RevFE
    Constant Bitrate faichiu's Avatar
    http://www.passmark.com/products/bit.htm
    Quote Originally Posted by SAScooby
    Hi
    98 Honda civic
    In-Dash LCD Monitor K-301
    cappuccino EZ3
    PIII-1.2GHZ
    256MB PC133
    40GB HD
    Holux GR 213 Sirf Star III GPS
    IguidanceV2
    CNX-P1900 power supply
    Sound Blaster Live USB
    Mar 2006
    Colorado, but Canadian!
    I think memtest86 http://www.memtest86.com/ definately checks the RAM very well. It takes a while and you have to boot off of it, but it gets the job done... slowly. Very robust software though. And it is free!
    Mar 2006
    Actually that "Hiren's Boot CD" contains memtest86 and other very useful things, get that and run 'em all! I like that, I'm going to download it now!
    Feb 2004
    thanks for the help guys
    isolated the problem to an overheating processor
    ditched the intel heatsink and put an aftermarket one on and all seems well
    Raw Wave tj!2k4's Avatar
    Oct 2004
    Quote Originally Posted by 2k1Toaster
    Hiren's is freakin sweet. Been using it for years now. :thumbsup:
    Sep 2003
    New Mexico, USA
    Quote Originally Posted by tj!2k4
    Me too! Though I've added a lot to it... my image is 690mb! Just tools and ****e I use everyday... I bet I don't need all of it though.
    Tidder
    Try RevFE
    Jan 2006
    Arkansas
    For burn in tests I use 3dmark03... Run it a few times in a row
    Jim
    2012 Honda Pilot (In Progress)
    2010 Honda Accord (After the Pilot)
    2008 Honda VTX1800N
  1. Replies: 42
    Last Post: 12-11-2009, 03:36 PM
  2. CarPal Bluetooth Module & Digimoto Software....A Very Good Combo..
    By jmciver in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 06-16-2006, 05:08 PM
  3. I want to test your software.
    By blk02si in forum StreetDeck
    Last Post: 03-14-2006, 04:51 PM
  4. Suggestion for the Software forum
    By Confused in forum Mp3car Forum Suggestions/Comments
    Last Post: 11-02-2004, 08:55 AM
  5. DDO software
    By Loftus in forum Software & Software Development
    Last Post: 04-01-2003, 11:26 AM
