Results 1 to 8 of 8
Thread: Slot loader transplant !
    Mar 2006
    Detroit MI. Westside(M-39 EXIT 9)
    Anyone ever put a slot loader in a laptop ? just checking my options peeps !
    Underconstruction for 2007 !!!!
    FLA gospeed.racer's Avatar
    Dec 2003
    Portland, OR
    Acer and Mac (amongst many others) have been doing it for a while.
    The form factor is the same, so its pretty easy.
    2005 Ford Focus ST
    I see dead kittens Quattro's Avatar
    Dec 2003
    New York
    Quote Originally Posted by A-day
    why couldn't u?
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    yeah, just get a slot/slim rom drive and swap em.. i have my car's slot load on this machine right now while i'm reinstalling the system
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Mar 2006
    ok that one was easy but this one's more hard. battery pinouts 4 a dell d510 latitude. it won't power up threw the adapter jack,but if u charge the battery in another laptop and put it back in it will work fine, so maybe i can power it threw the battery pins
    Dec 2003
    Portland, OR
    The D510 is just like most laptops by HP, Compaq, etc that all have a weak power jack. I have purchased laptops that do EXACTLY what your describing and after replacing the $10 eBay jack they work fine. Dont reinvent the wheel by hacking up the battery connector, just replace the bad part!
    EDIT: just checked eBay..they are more expensive (by quite a bit!), but still likely the issue. Plug in the adaptor and check power on the board, I bet it isnt getting thru the jack.
    http://cgi.ebay.com/New-Dell-Latitud...QQcmdZViewItem
    2005 Ford Focus ST
    Mar 2006
    You know i wanted 2 do that but i did want to take that long walk but if i do i geuss i could take avantage of the other features
    Variable Bitrate anky1's Avatar
    Apr 2005
    NJ
    how old is your 510? still under warranty? dell will in most cases just send you out a replacement part and you send back your broken one.
    RIP 1993 civic sedan
    RIP 1993 civic Del Sol
    Hello! VW Golf 1.8t
  1. lcd mount into weird slot
    By burnhamd in forum Fabrication
    Last Post: 08-27-2005, 09:08 PM
  2. Replies: 6
    Last Post: 02-16-2005, 04:05 PM
  3. slim slot loader drive from imac ... is there an adapter to USB?
    By mattress in forum General Hardware Discussion
    Last Post: 02-03-2005, 05:21 PM
  4. Problem with connecting 2 Type II pcmcia cards to a Type III slot.
    By AVmobile in forum General Hardware Discussion
    Last Post: 01-28-2004, 09:14 PM
  5. *one* bad pci slot? also, bad NIC?
    By InFix in forum General Hardware Discussion
    Last Post: 11-27-2002, 11:49 PM
