Results 1 to 3 of 3
Thread: Need help urgently, 12" lcd,DVD headunit VGA-RCA
    Jan 2006
    Unhappy Need help urgently, 12" lcd,DVD headunit VGA-RCA
    I have a carputer in my car, the motherboard the PSU and other bits and bobs are in the boot of my car, I have a 12" lcd screen in my dashboard which is connected to my computer by the standard 15 pin VGA cable, now I have bought a dvd headunit and want to connect my headunit to my screen, the headunit has video out cables of the RCA type. is it possible? if so how can I do it?
    Low Bitrate pancakeboy's Avatar
    Mar 2006
    Toledo
    Post
    Your dvd head unit SHOULD have some type of video input. I should be rca or s-video. To output video on the computer to the dvd headunit you would have to have a video card with rca or s-video out and run extended monitor. That should work
    Edit: Just re-read the post...for video in from headunit to monitor you would have to have rca or s-vid input on your monitor. If not, i think your out of luck, I dont think a rca-vga converter exist...
    Aug 2002
    Eau Claire, Wi
    of course it is possible. a quick ebay search turned this up. im sure they can be found for less.
    http://cgi.ebay.com/New-S-Video-Comp...QQcmdZViewItem
    System: AMD Duron 1200+ , 512 MB ram , usb sb mp3+ , Tview 7" touchscreen , M1-ATX PSU , Slot Load iMac DVD-Rom , 40 GB laptop HDD, netgear USB 802.11g
    Progress: Installation: 90% Dash fabrication: 80%
    Parts Needed: USB GPS
  1. Via Epia - can I use VGA and RCA video outs at same time?
    By nxt125 in forum General Hardware Discussion
    Last Post: 09-17-2005, 10:31 AM
  2. an LCD under $80 vga not rca . size= 5" or more
    By babas151 in forum LCD/Display
    Last Post: 05-22-2002, 10:35 PM
  3. Headunit with RCA Aux Inputs
    By thebigmoa in forum General Hardware Discussion
    Last Post: 03-05-2002, 11:08 PM
  4. Cheap VGA -> RCA converter (scan converter)
    By mprover in forum General Hardware Discussion
    Last Post: 06-22-2001, 09:29 AM
  5. Video out or VGA to RCA?
    By Steele in forum General Hardware Discussion
    Last Post: 12-16-2000, 05:25 PM
