Results 1 to 4 of 4
Thread: Desktop PSU rating
    Maximum Bitrate buurin's Avatar
    Sep 2005
    Seattle, WA
    Desktop PSU rating
    I modded my desktop PSU to connect it to my m1atx... I needed 2 12V(Pwr and Ign) lines, and a gnd.
    I took a 12V and gnd from one of the 4pin molexs, and another 12V from another molex
    I wired the 12V ign through a switch so I can turn the pc on/off. I turn the PSU on by shorting some pins on the big atx connector
    This setup worked once... Now the PSU turns on(fan runs), and there is 12V on the lines I have wired up but the PC does not come on. I was wondering if perhaps the 12V lines I took from the 4pin molex does not source enough current to run my pc... Should I take the 12V from the big atx connector?
    B Smoov
    Project Status: 90% Complete
    Next Step: TIVO for Radio
    Ampie Case :: MII10000 Mobo :: M1-ATX PSU :: 512MB RAM :: 2.5" HD, 60GB, 5400rpm, 16MB Buffer :: DWW-700H :: Centrafuse
    Maximum Bitrate mushin's Avatar
    Aug 2004
    SE Michigan
    Your problem may be elsewhere... Because the way most PSUs are designed (to save cost), they are not capable of outputting their full rating on the 12V rail unless the 5V rail is also adequately loaded. This has been causing some problems in standard system with high-end graphics cards too, where the 12V load far outstrips other loads.
    Still, I find it odd that it stays on and you're reading 12V. The problem may be with your m1atx. Does it still work off your car batt?
    Sep 2005
    Seattle, WA
    Yeah it works on my car battery... I was scared it wouldnt after it stopped working w/ the desktop PSU.
    Interresting info about the 5V rail load... Hmm.. That sucks...
    Any ideas for easily powering up my CarPC in my house? Ideally using a desktop PSU, but i suppose I am open to alternatives (except buying a car battery to sit in my living room )
    B Smoov
    Mar 2006
    Colorado, but Canadian!
    The 12volt off the big ATX connector should supply enough juice. Try that. You can get a 20pin ATX pin voltage chart from here I believe.
    You could also try a 12v transformer from Radio$hack for pretty cheap or rip one out of an old dying piece of electronics. That should give quite a bit of current, but you would want some way to regulate it.
  1. Replies: 5
    Last Post: 06-20-2007, 01:21 PM
  2. Mastero 3.5 12v-12v PSU KIT fs
    By SteveC in forum Classified Archive
    Last Post: 09-28-2004, 11:04 AM
  3. Powering up normal ATX PSU
    By KimaX in forum Power Supplies
    Last Post: 09-28-2004, 12:08 AM
  4. Morex 80w PSU not working?????
    By NiN^_^NiN in forum Power Supplies
    Last Post: 09-04-2004, 11:52 PM
  5. Inverter and PSU success
    By magnetik in forum Power Supplies
    Last Post: 09-22-2001, 07:19 AM
