Been using it for sometime now. Works great. Just make sure you use the new drivers from VIA Arena if you are experiencing problems with the ones supplied from the CD.
I am the happy owner of VIA EPIA SP 1.3, but few weeks ago new VIA EPIA EN 1.5 arrived in my mailboxFor now I installed Windows XP, as soon as I get few hours free time I will change the motherboards in my CarPC system. I will let you know about the difference comparing to SP 1.3.
The jetway J7F2 and the via EN 15000 are very similar but dont get the jetway. The board sucks in my opion. Check out the this theard & this thread about the board. Audio out sucks which I hear they are swapping resistors to fix the problem, bios suck you can not place the system into standby, and the board itself is unstable. They cut corners in building this board and it shows to keep the price down. I heard the life span on there boards is about 18 months. VIA board is way better and has a better reputation.
Opus case. MB 899 core duo 2.0ghz
Dual vga out, 400 gb hard drive, Centrefuse front end
zapco 1000.4 for zapco 6.5 componets
zapco 1100.1 for 2 13" W6.
This board is worth the price hike over there other boards. The resume from hybernation time is really fast. Performace wise it's pretty much equivilant to the Pentium M 1.73. This is a much better board than there C3. I am running dual video pci card with no problems. I couldn't get this to work with the M2 12000.
The only down fall is that there is no daughter board for pcmcia.![]()
If it had the PCMCIA slot, it would be a god send!
I'd love to run this board. Unfortunately, there doesn't appear to be an optical port on it...![]()
Jan Bennett
There is S/PDIF In and Out on headers on the EN, you just need to find the I/O bracket that will connect... Via don't supply one
I seem to remember Asus do one, with optical and RCA, be interested to know if you fnd one![]()
when they release this board with a pcmcia, maybe ill upgrade. untill then i like my audigy notebook. the onboard sound isnt powerful enough besides ill be going optical out soon. I think reds in the same boat.
MII12000 | 512MB PC3200 | 60GB 2.5" Samsung
M2-ATX 160W PS | SlotLoad DVD/CDRW | BU353 GPS
7" Lilliput 619 | WinTV | WIFI | Bluetooth
Audigy2 ZS | HQCT | Kyocera KR1 Mobile Router(3G)
Roadrunner | LSXvoid | IGuidance 3
My Worklog
the c7 processor is capable of going to 2ghz...which VIA has announced, I don't know when they'll be implementing that on their boards, but its soon to come once all the bugs of this are cleared up.
If this is the same board then it does.
http://www.epiacenter.com/modules.ph...&pid=92&page=7
HappyPills, that's the Phylon/Jetwayboard, which we're comparing to the Via EN
Red and yrean, the Via EN does have S/PDIF In and Out, but on pin headers, so you need to find the connectors for it... Via helpfully don't supply them. It also has YPbPr video on pin headers... again no connectors.
Reliability of both boards seems shaky at the moment, be good to hear from people that have had no problems at all wither with the Via EN or the Jetway/Phylon...
